Struggling with Calculating an Integral: Can Someone Help?
  • Context: Undergrad
  • Thread starter Thread starter dragonblood
    Integral
The forum discussion centers on calculating the integral \(\int_0^1{\frac{1}{1+\sqrt{x}}dx}\). The user initially attempted a substitution \(u=\sqrt{x}\) leading to the integral \(\int_0^1{\frac{1}{2u}\cdot\frac{1}{1+u}du}\), but encountered issues with logarithmic expressions. The correct transformation is \(\int_0^1{\frac{2u}{1+u}du}\), which simplifies the calculation. The discussion highlights the importance of proper substitution and manipulation of integrals for accurate results.
  • Understanding of integral calculus
  • Familiarity with substitution methods in integration
  • Knowledge of logarithmic functions and their properties
  • Experience with integration by parts
  • Study the method of substitution in integral calculus
  • Learn about integration by parts techniques
  • Explore the properties of logarithmic functions in calculus
  • Practice solving integrals involving rational functions
Students and professionals in mathematics, particularly those studying calculus, as well as educators looking for examples of integral manipulation techniques.
dragonblood
I'm having trouble calculating an integral:
I decided to do a substitution:
u=\sqrt{x}
du=\frac{1}{2\sqrt{x}}dx=\frac{1}{2u}dx
thus making the integral look like this:
I transformed this integral to:
\int_0^1{\frac{1}{2u}\cdot\frac{1}{1+u}du}=\int_0^1{\frac{A}{2u}+\frac{B}{1+u}du=\int_0^1{\frac{1}{2u}+\frac{(-1/2)}{1+u}du
And tried to solve the integral like this:
\ln|2u|-\frac{1}{2}\ln|1+u|
going from 0 to 1.
However, this means to insert 0 in an ln-expression. Obviously I have done something wrong? Can someone please help?
Nevermind. I did it now.
It was a simple mistake on my part.
The integral should look like:
after substitution
and then it should be calculated with integration by parts from there.
\left.{\frac{1}{1+\sqrt{x}}\right|_{x=1} = \left\{\frac{1}{2},\infty\right\}
I'm not entirely sure what that post means trambolin, care to explain?
Dragonblood - The solution comes out must quicker than integration by parts if you add and subtract 2 into the numerator.
I meant the -1 is causing the integrand blow up at x=1 for the cause of ln 0. But nevermind it is just the notation stuff...
Ah, yes. That is much easier :) Thanks
  • · Replies 19 ·
  • · Replies 21 ·
