Integrals: Solving with Substitutions
  • Thread starter Thread starter Jacobpm64
    Integrals
6 replies · 2K views
Jacobpm64
Find the integral.
http://img83.imageshack.us/img83/1228/int203bd.gif
This one is just so confusing. *sigh*
Find the antiderivative.
http://img83.imageshack.us/img83/7179/int264ol.gif
I don't know how to approach this one.. I'm guessing making some substitutions.. but i don't know how you actually work it when you make subtitutions.. just like in my other post.. I can make substitutions.. but i don't know what to do after that. I need one with substitutions worked for me if they're all similar.
Would it help you to see how a substitution works if I worked out a simple problem?
[tex]\int\frac{2x}{\sqrt{x^2+1}} \ dx[/tex]
[tex]u=x^2+1[/tex]
[tex]du=2x\dx[/tex]
[tex]\int\frac{1}{\sqrt{u}} \ du[/tex] <-Substitute values for u and du as appropriate.
[tex]\int u^{-\frac{1}{2}} du[/tex]<-Just rewriting the square root sign as a power of -1/2 to make it easier to see the integration.
[tex]2u^{\frac{1}{2}}[/tex]
[tex]2(x^2+1)^{\frac{1}{2}}[/tex]<--substitute back for u=x2
[tex]2\sqrt{x^2+1}[/tex]
Take a minute to understand why the substitution worked. You want to put everything in terms of one variable. By choosing u to be the value in the square root you obtain a value of du that matches the other x and dx values.
How's this for the first one?
http://img97.imageshack.us/img97/7520/inttry206vz.gif
And this for the second?
http://img186.imageshack.us/img186/6919/noworkint266iv.gif
Another one came out with an undefined answer, but the answer in the back of the book turned it into natural logs.. hmm.. i don't know how that works.. But following the same pattern.. i'd get..
http://img88.imageshack.us/img88/1598/workint262dh.gif
hmm?
Well see du is the differential of u...
If u is [tex]x^2+2x+2[/tex] then du would be [tex](2x+2)dx[/tex]
lol forget i said that..
ok, i understand how to get what du is equal to.. what i don't get now is.. in your example problem, you never substituted back for the value of du.. so would it even change my answer?
In the second integral: u=1-4x so du=-4dx NOT 2dx.
and [tex]\int u^{-1} du = lnu NOT u^{-1}/0[/tex]
Look a bit more carefully at dav2008's example. Do you see du anywhere in the expression: 2u1/2? That's why he never substituted the value of du back in.
