MHB Integrate 3/(x(2-sqrt(x))) - No Partial Fractions
  • Thread starter Thread starter araz1
    Integrate
The integral of 3/(x(2 - sqrt(x))) can be solved without using partial fractions by employing the substitution u = sqrt(x). This leads to the transformation of the integral into a more manageable form, specifically 6∫(1/(1 - v^2)) dv, which can be directly integrated. The discussion highlights a method involving a clever substitution to simplify the integral, ultimately resulting in an expression that involves an inverse hyperbolic trigonometric function.
  • Understanding of integral calculus and substitution methods
  • Familiarity with hyperbolic functions and their integrals
  • Knowledge of algebraic manipulation and simplification techniques
  • Experience with integration techniques excluding partial fractions
  • Study the method of integration by substitution in detail
  • Learn about inverse hyperbolic functions and their properties
  • Explore alternative integration techniques beyond partial fractions
  • Practice solving integrals involving square roots and rational functions
Students and professionals in mathematics, particularly those focusing on calculus, as well as educators seeking effective methods for teaching integration techniques without relying on partial fractions.
araz1
integral of 3/(x(2-sqrt(x))) using u=sqrt(x)?
But not using partial fractions
[math]\int \dfrac{3}{x(2 - \sqrt{x} )} ~ dx = \int \dfrac{3}{u^2 (2- u)} ~ 2u ~du = \int \dfrac{6}{u (2 - u)} ~du[/math]
Let's pull a trick that occasionally works. I'm going to let 2 - u = a - v and u = a + v. If we add these two equations we get 2 = 2a. Thus a = 1. So 2 - u = 1 - v and u = 1 + v. Putting this into your integral gives
[math]\int \dfrac{6}{u (2 - u)} ~ du = \int \dfrac{6}{(1 + v)(1 - v)} ~ dv = \int \dfrac{6}{1 - v^2} ~ dv[/math]
which you should be able to calculate directly. (Unless you know the trick to integrate this it is going to be difficult.)
-Dan
$u = \sqrt{x} \implies du = \dfrac{dx}{2\sqrt{x}}$
$\displaystyle 3 \int \dfrac{dx}{x(2-\sqrt{x})} = 2 \cdot 3\int \dfrac{dx}{2\sqrt{x}(2\sqrt{x} - x)}$
substitute ...
$\displaystyle 6\int \dfrac{du}{2u - u^2} = -6 \int \dfrac{du}{(u^2 - 2u + 1) - 1} = -6 \int \dfrac{du}{(u-1)^2 - 1}$
since partial fractions is off the table, the antiderivative will involve an inverse hyperbolic trig function
-Dan
Thank you for your time.
substitute ...
Why wouldn't you use partial fractions though?
