Integrating e^(x²) + 2e^(x²)x²
  • Thread starter Thread starter chwala
    Integration
15 replies · 2K views
chwala
[2][/2]
##∫e^x^2 + 2e^x^2x^2 dx##[/B]
i let## u= x^2, ⇒ du = 2x dx, ⇒∫e^x^2 dx = e^x^2/2x ## is this correct? by using integration by parts.... i am getting ##xe^x^2-e^x^2/2x##
You can verify whether you are correct by using wolframalpha.com. Also, your code has an error.
You may use integration by parts on the first term.
$$\int e^{x^2} \, dx=xe^{x^2}-\int x(2xe^{x^2}), dx$$
The equation above is sufficient for your problem.
Hope it helps.
Abhishek Sethi said:
You may use integration by parts on the first term of the equation.
Hope it helps.
i can see you are using integration by parts, what is your ##u, du, v, dv##?
I am not sure what you exactly mean by ##u,v,du,dv##. To put it more clearly,
$$\int e^{x^2} \, dx=(e^{x^2})\int 1\ dx-\int x\frac{d(e^{x^2})}{dx} dx$$
this is something "new " to me in my understanding integration by parts is ##∫udv= uv - ∫vdu## unless you have used a different approach, your method can't be described as integration by parts as stated in your opening statement.
i can see you picked ## u= e^x^2, dv=1 ⇒v=x, u'=2xe^x^2 ##
Thanks Abishek...greetings from Africa
i don't know when you continue with the integration of the second term the function is getting complicated i.e if you ∫2x^2e^x^2 dx or are we picking again
dv = 1, u= 2x^2e^x^2?
on ∫x.2xe^x^2 dx i let dv= x^2⇒ v=(x^3)/3, u= e^x^2 ⇒ du = 2x.e^x^2 thus
∫x.2xe^x^2 dx = (2e^x^2.x^3)/3-2 ∫(x^3)/3.2x.e^x^2 dx without simplification...this to me gets more complicated and no final answer is possible...
lol lol lol i was blind but now i can see...
∫(e^x^2+2e^x^2x^2)dx= xe^x^2- ∫2e^x^2x^2dx + ∫2e^x^2x^2dx + k
= xe^x^2 + k
chikhabi from Africa lol
chwala said:
## ∫ e^x^2 + 2e^x^2x^2 dx##
##\int e^{x^2} + 2e^{x^2}x^2 dx## (fixed by SammyS.)
I let## u= x^2, ⇒ du = 2x dx, ⇒∫e^x^2 dx = e^x^2/2x ## is this correct? by using integration by parts.... i am getting ##xe^x^2-e^x^2/2x##
It's good to see you trying to use LaTeX, but you are having some problems.
Is this what you mean? ##\displaystyle\ \int \left( e^{x^2} + 2e^{x^2}x^2 \right) dx\ ## It's difficult to tell with all of those run-on exponents.
yes that is what i mean...how do i type that in latex?
Easiest way: Hit "Reply" link under my post. See the coding.
Otherwise, for some LaTeX here in PF that you don't such access to: Right click on the LaTeX expression. Click on "Show Math As". Click on "TeX Commands". A pop-up window should appear with the LaTeX code.
The \displaystyle LaTeX command you see in my code gives larger format when doing "in-line" LaTeX using the ##\ \text{## ... ##}\ ## delimiters.
Also, look up LaTeX tutorial here in Physics Forums.
##\left| \frac a b \right|## am trying practise on latex...
##\left[ 1 - \left( \frac a x \right)^2 \right]^{-1/3}##
##\int x^2e^x \, dx##
##{ \displaystyle\ \int \left( e^{x^2} + 2e^{x^2}x^2 \right) dx\ }##​
You can also do it in plain text, just by using parentheses correctly. When you write e^x^2 that could mean ##e^{x^2}## or ##(e^x)^2 = e^{2x}##. In plain text you would write the first as e^(x^2) and the second as (e^x)^2.
