Integrating an inequality for two functions of the same variable
  • Thread starter member 731016
9 replies · 2K views · last reply
member 731016
Please see below
Please see below
For this true or false problem,
The answer if false, however, I am confused by this result as my working shows that the is true.
My working is, integrating both sides of the inequality we get ##\int f'(x) dx> \int g'(x) dx## for all ##x \in (a,b)## which is the equivalent to ##f(x) > g(x)## for all ##x \in (a,b)##.
Does someone please know what I have done wrong?
Thanks!
Counterexample: ##f(x)=-e^{-x}## and ##g(x)=1##. Then for all ##x##: ##f'(x)>g'(x)## but ##f(x)<g(x)##.
  • Love
Thank you for your reply @renormalize!
Sorry I am tying to generalize this without considering specific counter examples. I am trying to consider the most general case, this is why I integrate.
Thanks!
But this single counterexample is sufficient to show that your "general case" cannot be proven. Hence statement 6 is False, with no further work needed.
  • Love
Thank you for your reply @renormalize !
Sorry I am still confused. I integrated the inequality and obeyed the laws of algebra and my integration still worked. I'm not sure what is going on, I think maybe the question is wrong.
Thanks!
Thanks!
You can take the counterexample and put it in your chain of arguments to see at which step it fails. You can also use - which is what I do first - the fundamental theorem of calculus, either for the entire interval ##(a,b)## or for ##(a,x).##
  • Love
Don't forget about that sneaky constant that you should add when you evaluate an antiderivative.
If ##f' > g'## on (a,b), then what can you say about comparing ##\int {f'} + c_1## to ##\int {g'} + c_2##?
In other words, does the slope of ##f## being larger mean that the value of ##f## will be larger? Compare f(x)=2x with g(x)=x+1000 on (0,1).
  • Love
That's why I like FTC as a first test. It forces you to use the constants and can help to see where a general argument might fail.
  • Love
##\int (f-g)'>c> 0 ##
It would work if we had ##\int f'-g' =0 ##, with an equality at some value ##x,## so that ##f(x)=g(x)##, i.e., if they're equal at some point and grow at the same rate . Like Fact Checker mentioned, said, one just grows faster than the other, but you don't have additional knowledge of initial conditions. This is a sort of PDE without additional conditions and an inequality.
  • Love
The following inequality is true: if [itex]f(x) \leq g(x)[/itex] on [itex][a,b][/itex] then [tex] \int_a^b f(x)\,dx \leq \int_a^b g(x)\,dx.[/tex] (We can replace the upper limits with an aarbitrary [itex]t \in [a,b][/itex].) Replacing [itex]f[/itex] and [itex]g[/itex] by derivatives and using the fundamental theorem, this implies [tex] \forall x \in [a,b] : f'(x) \leq g'(x) \quad \Rightarrow \quad \forall x \in [a,b] : f(x) - f(a) \leq g(x) - g(a).[/tex] What this is saying is that if [itex]f[/itex] increases more slowly than [itex]g[/itex] and they start in the same place, then [itex]f[/itex] will be less than [itex]g[/itex].
  • Love
