Integrating cos^(5)(4x)
  • Thread starter Thread starter frasifrasi
    Integral
14 replies · 2K views · last reply
frasifrasi
For the integral
cos^(5)(4x), can I just integrate it directly to -1/4*sin^(6)(4x)... or which technique should I use?
Nope you can't do that. To make things easier, you may want to sub u=4x first, and then you have to use a trig identity to make the (cos(u))^5 "easy" to integrate.
Hint: [tex]\sin^2{x} + \cos^2{x} = 1[/tex]
frasifrasi said:
For the integral
what is the derivative of your answer then? it will not give you your original problem.
remember, when you're dealing with powers, you have to take into consideration the "chain rule."
But then I would have two 1-sin^2(X) in the integral, is there an easier way?
As neutrino suggested, after obtaining cos^5(u) write it as cos^4(u)*cos(u) = ((1-sin^2(u))^2)*cos(u). Now giving sin(u)=v, can you proceed?
Ok, so i get:
(1-v^2)^2 dv
= 1 - 2(v^2) + v^4...
Now, I have to integrate the whole thing?
How would I sub back? --let v = sin(4x)?
v = sin(u) and u=4x.
You've expanded the brackets in the post above but did you integrate it?
If you are only interested in questions that can be done trivially, then I recommend you drop calculus.
Do you really consider it too difficult to integrate
[tex]\frac{1}{4}\int (v^4- 2v^2+ 1)dv[/tex]?
I second Halls of Ivy. I am not sure what is so difficult here. It is a matter of individually integrating 3 simple terms and then plugging in for v.
In the time it took to write too much work for this question, you could have finished!
Casey
frasifrasi said:
Sorry I offended your wife. In context, my statement is valid...
I have no idea what this means.
I think frasifrasi means that they only wanted to know how to substitute back for v once the integration was done so it was too much work to put the full integration in the previous post for the relatively simple clarification.
Yeah, I was just saying that more work wasn't really necessary, not meaning to complain in any way.
but hey, I have another question...
For the series (-1)^(n)/ln(n), I used the alternating series test to show that it converges, but how do I show that it converges conditionally?
If I look at the abs value 1/ln(x) , I am not sure how to establish that it diverges...
Thank you for the help!
