Integrating Exponential Function with Infinite Upper Boundary
8 replies · 6K views · last reply
dj023102
if f(x) = pi*xe^(-x^2)
integrating this function if the lower boundary is 0 and the upper boundary is infinity is the answer pi*(2e-1). is this right?
Can you think of an appropriate substitution that may help with this integral?
Could you show your work? I'm pretty sure that isn't the correct answer, but it is difficult to tell if you don't show how you arrived at it.
sure i used substitution method.
let u = -x^2
then du/dx=-2x, dx=du/-2x
this gives the integral of xe^u/-2xdu
=pi/2 integrate e^u lower boundary 0 upper boundary infinity
then separating the two integral, one integral with lower boundary 0 and upper boundary 1 and the second integral with lower boundary 1 and the upper boundary infinty.
the first integral gives e^1-e^0 and the second integral we get e^1.
then adding them together we get
(pi/2) * (e-1+e) is that right?
let u = -x^2
It's hard to follow your work. Add some empty lines to make reading easier. Using Latex helps a whole lot.
It shouldn't be e^u, it's slightly off. And what do you mean by "separating the integral"? You mean integration by parts? It's not needed here.
let u = -x^2
More simply, if u= -x2, then du= -2x dx or -(1/2)du= dx
[itex]xe^{-x^2}dx[/itex] becomes [itex]e^{-x^2}(xdx)= -(1/2)e^u du[/itex]
When x= 0, u= 0 and when x="infinity", u is -"infinity" The integral becomes
[tex]\int_0^\infty xe^{-x^2} dx= -\frac{1}{2}\int_0^{-\infty} e^u du[/tex]
[tex]= \frac{1}{2}\int_{-\infty}^0 e^u du[/itex] <br /> <br /> I can see no reason to "separate" at x= 1. In any case, since x=1 is an upper limit for one integral and a lower limit for the other, those terms will subtract, not add, and will cancel.<br /> <br /> And there certainly is no reason to have a "pi" in there![/tex]
No, I just looked back and realized you had a "pi" in the original integral that you then dropped.
Including that pi,
[itex]\frac{1}{2}\pi \int_{-\infty}^0 e^u du= \frac{\pi}{2}e^u\right|_{-infty}^0= \frac{\pi}{2}[/tex][/itex]
