Integrating Factor Method: Finding the Solution to a Cosine Equation
9 replies · 2K views · last reply
_N3WTON_
Find the general solution to the indicated equation:
[itex]cos(x)y' + ysin(x) = 1[/itex]
[itex]e^\int p(x)\,dx * y(x) = int\ f(x)\, dx e^\intp(x)\,dx + C[/itex]
Ok, I am having trouble getting started with this problem because I am not really sure what value to assign to p(x). I attempted to assign p(x) = sin(x) therefore u(x) = e^cosx. However, I do not believe that e^cosx can be integrated without using some advanced techniques, so I am quite sure I am not doing the problem correctly.
Edit: when I say e^cosx cannot be integrated I mean not in terms of elementary functions
Edit: Sorry about the bad Latex equations, I am attempting to sort it out (I have never used it before)
[itex]e^\(int p(x))\,dx * y(x) = int\ f(x)\, dxe^\intp(x)\,dx + C[/itex]
To calculate the integrating factor your equation needs to be in the form$$y' + p(x)y = q(x)$$So you need to start by dividing your equation through by ##\cos x## before trying to evaluate the integrating factor.
thank you, so then the equation would become:
[itex]y' + ytan(x) = sec(x)[/itex] and
[itex]p(x) = tan(x)[/itex]
right?
right?
Yes. The integrating factor of [itex]e^{\int \tan x \,dx}[/itex] should now work as advertised. :) Just be sure to note whether the points for which cos(x) = 0 are to be included in the domain of the solutions.
Edit: I mean can [itex]e^{sec^2x} * secx[/itex] be integrated? Because that is what I'll end up with no?
sec2(x) is not an integral of tan(x). Remember we need to find a function that has tan(x) as its derivative. Try writing tan(x) as [itex]\frac{\sin x}{\cos x}[/itex].
ahh...thanks, sorry about the silly mistake
ok, for my final answer I am getting:
[itex]y(x) = sin(x) + \frac {C}{sec(x)}[/itex]
That looks fine. However, it may be preferable to write the solution as [itex]y(x) = \sin x + C\cos x[/itex], since both this function and the original differential equation is defined for all x, while your function is not defined for some of the values of x for which the original differential equation is defined. :)
thanks again, I'll do that
