frozen7
- 163
- 0
[tex]\int \frac{1}{x^2 +4}[/tex] How to integrate this without knowing the derivatives of inverse function?
You can use some basic algebra and the method of partial fractions..frozen7 said:[tex]\int \frac{1}{x^2 +4}[/tex] How to integrate this without knowing the derivatives of inverse function?
what said:this integral can be done in two steps, one is a regular substitution that gets it in a form such as 1/(u^2 +1) and another trig substitution after that.
Are you sure the substitution is [itex]x = \tan \theta[/itex]?what said:I'll assume you can do the first step, then use the trig substitution x = tan(θ). Remember after you have your answer you have to get it back in terms of x, your answer will be in terms of theta.
Edit: forgot a comma and a then, it might make it confusing.
marlon said:maverick, the substitution is not u=2x but u=x/2
[tex]\frac{1}{x^2+4} = \frac{1}{4(\frac{x^2}{4} + 1)}[/tex]
marlon
maverick6664 said:oh my bad! Thank you!
Then correction:
[tex]\frac 1 2 \int \frac 1 {u^2+1} du = \arctan(x/2)[/tex]
marlon said:I don't want to be whinning but the right hand side of your equation is not correct either. You are forgetting something :)
marlon
maverick6664 said:maybe i need sleep. It's 3:30am.
marlon said:Aha, that happens to me too.
Here in Western Europe it's 19.30 pm and i am looking foreward to attend the SAW2 premiere tonight.
OOHH YES, THERE WILL BE BLOOD
Sleep well :)
marlon
BecausePseudo Statistic said:What's up with all of the arctans? Why not be frank with the function and do what you got to do... use partial fractions!?
It will-- you could then convert back to arctan using the definition of the function from Oiler's formula... the final answer will always be real wherever arctan is defined as real.. so why not?marlon said:Because than you would be needing complex functions. That's against the rules if the calculus must remain "real"...
[tex]\frac{1}{x^2+a^2} = \frac{1}{x+ia}\frac{1}{x-ia}[/tex]
marlon
Pseudo Statistic said:It will-- you could then convert back to arctan using the definition of the function from Oiler's formula... the final answer will always be real wherever arctan is defined as real.. so why not?
what said:Here is the solution i was hinting at, without knowing the derivative of inverse tangent...
[tex]\int \frac{1}{x^2+4} dx \ u = x/2 \ du =1/2 dx [/tex]
[tex]1/2 \int \frac{1}{u^2+1} du \ u =\tan(\theta) \ du = \sec^2(\theta) d\theta [/tex]
[tex]= 1/2 \int \frac{\sec^2(\theta)}{\tan^2(\theta) +1} d\theta = 1/2 \int \frac{\sec^2(\theta)}{\sec^2(\theta)} d\theta = 1/2 \int 1 \ d\theta[/tex]
[tex]= 1/2(\theta + C)[/tex]
Now we have to bring back in terms of x so we use the way we defined the substitutions to help us..
[tex]\theta = \arctan(u) = \arctan(x/2)[/tex]
therefore...
[tex]\int \frac{1}{x^2+4} dx = 1/2\arctan(x/2) +C[/tex]
