Integrating ln(sqrt(t)/t) using u-substitution
  • Thread starter Thread starter judahs_lion
    Indefinite
37 replies · 4K views
judahs_lion
integrate lnsqrt(t)/t , dt
This is the most i can come up with.
u = lnsqrt(t), so du = 1/(2sqrt(t))dt , so dt = 2du/sqrt(t)
Im stuck @ this point
Hint: The logarithm function has an interesting property.
[tex]ln\left(a^{b} \right) = bln\left(a \right)[/tex]
du isn't 1/(2*sqrt(t))*dt. You are forgetting to use the chain rule. You can also get the correct differential by applying the rules of logs to ln(sqrt(t))=ln(t^(1/2)).
so i would integrate (lnt^(1/2))/t ?
Sure. Isn't ln(sqrt(t))/t=ln(t^(1/2))/t?
Ok, now I'm not sure what to take as u.
Yes.
But follow Dicks' suggestion also. It would be helpful to you. Your original method was correct ,however, as already pointed out you weren't differentiating correctly.
? Take u the same as you originally chose. u=ln(sqrt(t))=ln(t^(1/2)). They are the same thing. You just have to compute du correctly. That's where your first attempt went wrong. The du was wrong.
Yea i think i integrated rather then differentiated to get du. so u = 1/2lnt , du = 1/2(1/t)dt?
that would make give me 1/2lnt (1/t), which is udu +C. so it breaks down to u^2/2 + C?
Sure. You could have also done it with ln(sqrt(t)). (ln(sqrt(t))'=(1/sqrt(t))*(dsqrt(t)/dt)=(1/sqrt(t))*(1/(2*sqrt(t)))=1/(2t). That's the chain rule. BTW if you aren't going to use TeX you should probably use a few more parentheses. 1/2lnt could mean (1/2)ln(t) or 1/(2ln(t)) etc.
Okay I'll think about that next time.
judahs_lion said:
Is that implicit differentiation?
No all it is is just normal differentiation. See all you have to do if factor out the constant( 1/2 in this case). So it would look like [tex](\frac{1}{2}) * (\frac{d}{dt})(ln(t)) = \frac{1}{2t}[/tex]
but i thought the 1/2 would be eliminated because it is a constant
If you can factor out a constant, then do so. Plus if you look at the link that I gave you. There should be a "Show Steps" link. It says to factor out the constant.
AND even if you do it by using the product rule (I'm doing this so you can see that the 1/2 stays)
[tex](\frac{1}{2}[(\frac{d}{dt})(ln(t))] + (\frac{d}{dt})(\frac{1}{2})(ln(t))[/tex]
We have [tex]\frac{1}{2}*\frac{1}{t} + 0(this-is-the-derivative-of \frac{1}{2}) * ln(t)[/tex]
so this shows that the derivative of [tex]\frac{1}{2} * ln(t) = \frac{1}{2t}[/tex]I hope you understand!
Thank you
judahs_lion said:
Thank you
Ok, so after all that fuss, you can do the integral, right?
not really. I am thinking insted of it substituting to udu, it would be something like u((1/2)du)?
Argh. Why don't you use the original substitution you suggested, u=ln(t^(1/2)). It works great. I promise you.
I promise too :).
I just don't see it. Don't see du inside the original function.
I'm going to have to ask you again. If u=ln(t^(1/2)), what's du? Why don't you see du (or some constant multiple of it) in the original function?
du = 1/(2t). Only thing i can think of is bringing the 1/2 down but don't see how that helps me.
It's du=(1/(2t))*dt, ok? Can you show what you get when you use that substitution into the original integral?
judahs_lion said:
2(udu) ?
I think that that's supposed to be [tex]2\int udu[/tex]
yea, i don't know have to use symbols in here.
