Integrating sin²(x - π/6)
  • Thread starter K.QMUL
    Integrating
14 replies · 6K views · last reply
K.QMUL
Hi there everyone,
∫ sin^2(x-pi/6) dx
I have the following integral to solve but am unsure where I should start, I first thought about integrating by parts as I thought you could split it into [Sin(x-pi/6)][Sin(x-pi/6)]. But couldn't seem to figure that out. I was wondering if you could use a trig identity but again am unsure which one.
Any suggestions?
Use the double angle formula. This is a very handy formula to reduce the exponent in a trigfunction appearing in your problem.
Integration by parts works nicely as well, if you are careful with your notation.
which double angle formula would I use, we still have a Sin^2 to deal with
Well, use the double angle formula in which sin^2 appears on its own, of course.
I have completed the question using the double angle formula, could you tell me if you find any errors, as I am still unsure whether I have done this right or not.
Thanks
  • Handwritten integration working on ruled paper: sin²(x - π/6) rewritten with sin²A = ½[1 - cos 2A], then ½∫[1 - cos(2x - π/3)] dx, giving ½(x + ½ sin(2x - π/3)) dx.
Thanks
There is a sign error in the end. What is ##\displaystyle \int \cos(x) \, dx##?
oh, I realize my mistake, integrating cos(x) = sin(x)
You can always check your answer by differentiating it and seeing if you recover the integrand.
So I've completed the question, and checked if I get the original answer by differentiating it. And it seems good. HOWEVER, I have one concern; when you use the double angle formula, can I take 'A' as (x - pi/6) in sin^2(x-pi/6) or would I need to split it somehow. Please clear up my confusion.
What does 'A' represent?
In the identity, you can replace 'A' by anything as long as you replace it with the same thing everywhere. Setting A to ##(x-\pi/6)## is perfectly fine.
