Integrating Using Partial Fractions
5 replies · 2K views · last reply
Jay9313
This is an arc length problem in three dimensions. I was given the vector r(t)=<et, 1, t> from t=0 to t=1
Arc Length= [itex]\int[/itex] |[itex]\sqrt{r'(t)}[/itex]| dt from t1 to t2
where |[itex]\sqrt{r'(t)}[/itex]| is the magnitude of the derivative of the vector
I took the derivative and got the magnitude and simplified it down to
∫ √(e2t+1) dt
I then set u=e2t+1
I then simplified and substituted until I got to:∫[itex]\frac{\sqrt{(u)}}{u-1}[/itex] du
My professor said to use partial fractions from here, but I'm not sure how to do that.
Try one more substitution to get rid of the square root on top first. Then do partial fractions.
I split it up, and it made it worse, and I had to do long division, but I got an answer. It's nasty, but I got an answer.
Presumably, you ended up with something like ##\frac{v^2}{v^2-1}## after the substitution. A good technique to avoid doing long division is to add and subtract judiciously:
$$\frac{v^2}{v^2-1} = \frac{(v^2-1)+1}{v^2-1} = 1 + \frac{1}{v^2-1}.$$
