Find Area Enclosed by Y-Axis, y=3 & x=y^2
  • Thread starter Thread starter zebra1707
    Areas Integration
The area enclosed by the y-axis, the line y = 3, and the curve x = y² is calculated as 9 square units using the integral from 0 to 3 of y² dy. When considering the volume of revolution around the y-axis, the correct formula is π∫[0 to 3] (y²)² dy, which simplifies to π[243/5] cubic units. The initial miscalculation of 48.6 cubic units was corrected to 48.6π cubic units, emphasizing the importance of including π in volume calculations.
  • Understanding of integral calculus, specifically definite integrals.
  • Familiarity with the concept of area under curves.
  • Knowledge of volumes of revolution and related formulas.
  • Ability to manipulate and simplify algebraic expressions.
  • Study the derivation of the volume of revolution formula for curves rotated about the y-axis.
  • Practice calculating areas and volumes using different curves and axes.
  • Explore applications of integration in real-world scenarios, such as physics and engineering.
  • Review common mistakes in integral calculus to avoid errors in future calculations.
Students studying calculus, educators teaching integral calculus, and anyone interested in mastering the concepts of area and volume in mathematical analysis.
zebra1707
Find the area enclosed by the y axis, the line y = 3 and the curve x = y^2
[/b]3. The Attempt at a Solution [/b]
Area = \int 3 to 0 y^2.dy
= (1/3 y^3) 3 to 0
= (1/3 x 27)
= 9 sq units
Im not really confident on the y-axis questions, can you please confirm my understanding. If this same area is then rotated 360 degrees about the y -axis, can I seek guidence on how to do this. Cheers P
What you did is correct. If you aren't comfortable with questions involving the y-axis, you can always change the question so it can be equivalently integrated with the x-axis. For example, x=y2 between y=3 and the y-axis has the same area as y=x2, x=3 and the x-axis :smile:
Do you know the formulae (or even better, derive the formulae) for volumes of revolution?
If y=f(x) is rotated about the x-axis between a and b, the volume is \pi\int_a^b\left(f(x)\right)^2dx
Thanks Mentallic
Yes, I realize I know the volume formulae. I calculate the volume would be 48.6 units cube - do you mind checking?
Cheers P
Um, no. Show me your working and I'll point to where you went wrong.
Yeah exactly, so why are you saying it's 48.6 u3? Whatever happened to the \pi? :-p
Sorry, oooopppsss, can I say 48.6pi u3? I got the impression that I had gone horribly wrong. Manythanks for you responses.
Cheers P
Of course, all you did was convert the fraction to a decimal, so there's no point but yeah, sure I guess :-p
  • · Replies 20 ·
