Integration which possibly involves partial fractions.
10 replies · 2K views
kirakun
Well this is part of an integration process, namely:
[tex]\int \frac {sin^2x}{4+3cos^2x}dx[/tex]
My attempt involved using a u-substitution, namely t = tan x
Using t = tan x, [tex]sin^2 x = \frac {t^2}{1+t^2}[/tex] and [tex]cos^2 x = \frac {1}{1+t^2}[/tex]
we have [tex]\int \frac {sin^2x}{4+3cos^2x}dx[/tex]
which becomes
1. [tex]\int \frac {t^2}{(1+t^2)(4+ \frac {3}{1+t^2})} \times \frac {1}{1+t^2}[/tex]
2. [tex]\int \frac {t^2}{(1+t^2)( \frac {4+4t^2+3}{1+t^2})} \times \frac {1}{1+t^2}[/tex]
and finally yields
[tex]\int \frac {t^2}{(7+4t^2)(1+t^2)}dt[/tex]
So i am basically stuck at this point and cannot proceed further.
Maybe i should have used another substitution or I started it wrongly.
I cannot seem to get to the solution though i suspect arctan might be present in the answer.
Please do guide me.
Thanks again.
It's not clear why you chose t = tan x as your substitution.
It's also not clear how you obtained the integral in t after substituting. You clearly wound up with a more complicated integral using the t substitution. You should show all the steps you took to make sure you haven't made any mistakes.
What method do u think would be best to tackle this one? well i chose tan x because with the denominator containing terms squared, i thought i would end up with an arctan case, but the [tex]t^2[/tex] in the numerator after simplifying makes it harder to achieve the form if not impossible.
Also when t = tan x, [tex]sin^2 x = \frac {t^2}{1+t^2}[/tex] and [tex]cos^2 x = \frac {1}{1+t^2}[/tex]
Upon substituting including the dx i ended up simplifying it like i showed.
I am still trying some other methods...
Partial fractions, as you suggested. Did you try that?
It will be of the form
[tex]\frac {At+B}{1+t^2} + \frac {Ct+D}{7+4t^2}[/tex] right?
Consequently
For the numerator,
[tex]t^2 = (At+B)(7+4t^2) + (Ct+D)(1+t^2)[/tex]
[tex](4A+C)t^3 + (4B+D) t^2 + (7A+C)t + (7B+D) = t^2[/tex]
Comparing coefficients of t^2 and comparing constants we get the 2 equations respectively;
4B + D = 1 and 7B+D = 0
which gives B = - 1/3 and D = 7/3
A and C being both 0
Thus the partial fraction is
[tex]\frac {7}{3(7+4t^2)} - \frac {1}{3(1+t^2)}[/tex]
But on expanding it does not give t^2 in the numerator, am I doing something wrong?
I'll be trying this.
Since your integrand fraction only has t2 terms, no odd powers, the partial fraction expansion must have A = C = 0. (Imagine substituting u = t2 first.)
Alright. But it should give the same answer as in my edited post
Check that again. It does for me.
Oh god yes, i forgot the 9 in the denominator. Well that partial fraction makes the integrand now easier.
I should complete the denominators to the square and use arctan integral?
Use arctan, yes. No need to complete any squares.
Thank you!
