Intensity-wavelength graph for X-ray
1 reply · 4K views · last reply
Titan97
Intensity against wavelength graph of an X-ray spectrum: a smooth continuous curve rises from zero at a cut-off wavelength, peaks, then falls, with sharp spike lines superimposed on the curve.
The cut-off wavelength is the minimum wavelength of the X-ray emitted. But doesn't minimum wavelength correspond to maximum energy? Why is intensity zero at minimum wavelength? Shouldn't it be maximum when wavelength is minimum since ##\lambda=\frac{hc}{E}##
Yes it does.
Because there are no x-rays emitted at that wavelength.
Unless you have a special reason to think that more light will be emitted at high energies than low energies.
I think you may be getting confused between wave a particle models for light - ##E=hc/\lambda## is the energy of an individual photon - the intensity is the number of photons per unit area per unit time. The relation means that it takes fewer short-wavelength photons to produce a high intensity light.
