Interacting Systems - The Sled Dog
  • Thread starter mantillab
    Systems
6 replies · 48K views · last reply
mantillab
The sled dog in figure (attached) drags sleds A and B across the snow. The coefficient of friction between the sleds and the snow is 0.10.
If the tension in rope 1 is 150 N, what is the tension in rope 2?
F_a on b = -F_b on a
The force diagrams I did for sled A and sled B resulted in:
Sled A: Fnetx = T1 - (mu_k)(m_a)(g) = 52
Sled B: Fnetx = T2 -T1 - (mu_k)(m_b)(g) = T2 - 228.4
My solution for T2 = 280 is very close, but not the right solution. Should I be adding another force for sled B, based on the friction of sled A or another component of sled A?
  • Diagram of a sled dog pulling two sleds in a line: sled A labeled 100 kg, sled B labeled 80 kg, joined by rope 1 and rope 2 to the dog at right.
Apparently the answer is 270N. Still don't know they determined that.
What are the masses of the sleds? I can't see the picture but I'm imagining that a dog is pulling sled b which is connected to sled a like so.
Dog--b--a
I don't know if this is what you meant, but Fnet for sled a and b are NOT the same unless they have the same mass.
Solution
T for rope 1:
100kg * a = 150 N
a = 1.5 m/s^2
T for rope 2:
(mass of sled 1 + sled 2)*1.5 m/s^2 = T
(100kg + 80kg)*1.5m/s^2 = 270N
kster you ignored the friction force.
Rope 1:
T-Mkn=ma
150-0.10(100*9.8)=ma
rope 2 just the same expect for the weight is 180kg
So to Sum it all up...
Remember when dealing with any type of friction problem, you MUST add it into the eq. usually by finding the F_net along the y-axis.
F_net_y = m_1 *a_y (a_y = 0, since the object is not moving in the y-direction)
Find all forces acting on the y-axis to be your F_net_y
F_net_y = N - m*g
N - m *g = m_1 *a_y
N - m *g = 0
N = m *g
Also remember what your Friction Force is.
F_k = U_k * N
F_k = U_k * (m *g)
Now you can solve for a
T_1 - F_k = m_1 *a
(T_1 - F_k)/(m_1) = a
(T_1 - (U_k *(m_1 *g)))/(m_1) = a
Then you solve for T_2
T_2 - T_1 - F_k = m_2 * a
T_2 = (m_2 * a) + T_1 + F_k
T_2 = (m_2 * a) + T_1 + (U_k *( m_2 *g))
