Interaction of dust and starlight - extinction
The discussion revolves around the effects of interstellar dust on the observed brightness of a star, specifically focusing on the concept of optical depth and magnitude changes due to extinction. The original poster seeks clarification on their calculations regarding the optical depth and the method for determining the star's apparent magnitude without the influence of dust.
  • The original poster attempts to verify their calculation of optical depth and the method for adjusting the apparent magnitude based on the change in magnitude due to dust. Participants question the interpretation of the change in magnitude and its application to the apparent magnitude calculation.
Participants are actively engaging with the original poster's calculations and assumptions. Some guidance has been provided regarding the relationship between apparent magnitude and the change in magnitude, but there is no explicit consensus on the final approach to calculating the new apparent magnitude.
The original poster mentions a hypothetical scenario involving specific parameters for dust grains and their effects on starlight, which may influence the calculations and interpretations discussed.
henrco
Hi,
I haven't posted an Astronomy question before. I did see some Astronomy questions in this section so I posted it here. But if it's in the wrong place, for future reference, please let me know where it should be posted.
1) The first problem I need guidance on is the value I have obtained for the optical depth. It seems very high, but checking my calculations carefully I'm sure I haven't made a mistake.
2) The other problem I have is if I am correct in obtaining the final answer by subtracting the change in magnitude from the stars apparent magnitude. Since I need to obtain the magnitude without dust I subtracted the change in magnitude value.
Any guidance very welcome!
1. Homework Statement
A hypothetical interstellar cloud consists of a large number of identical dust grains of radius0.1 μm and which have an extinction efficiency factor 0.75 at wavelengths corresponding to the standard V filter. A star is observed through this cloud and its apparent magnitude is V = 14.2 mag.
The column density of the sightline is Ndust = 5.8 × 10^14 m2.
Suppose that all the grains ofdust were to be removed from the sightline. What would the star’s
apparent V magnitude then be?
Something went wrong with powers of 10 towards the end.
1.13*10-5 is not 1.13*10-5%, and the opposite is not 99.99%.
The 14.87 should be the change in magnitude, not the new magnitude (note that it does not depend on the old magnitude). The difference between that and the magnitude is not the difference in magnitude.
Thank you for the response and guidance.
i) I saw my mistake regarding powers of 10 and corrected it.
ii) The change in magnitude comes out to 14.87
Finally I need to calculate the change in apparent magnitude, the current apparent magnitude is 14.2
and the change in magnitude is 14.87. However I'm hitting a metal block trying to work this out.
Appreciate any guidance to help me calculate the new apparent magnitude.
The dust makes the star dimmer, so the star is brighter than we see it. Does that mean you have to add or subtract the two numbers?
Thank you for the prompt reply.
The lower the value for apparent magnitude the brighter the object appears.
So I would say you subtract the change in magnitude. So 14.2 - 14.87 = -0.67
Right.
Thank you.
