Interactive Visualization for Adding/Subtracting Planes
The discussion revolves around understanding the intersection of two planes represented by Cartesian equations and how subtracting these equations can help visualize their relationship. When two planes intersect, subtracting their equations eliminates one variable, resulting in a line equation that represents the intersection. If the subtraction yields a solution of zero, it indicates that the planes are parallel and do not intersect. The mathematical concepts involved are part of linear algebra, specifically the method known as elimination. Visual aids like animations or diagrams are suggested to better grasp these three-dimensional relationships.
starlightx
Does anyone know of any interactive/good visual website for the adding and subtracting of planes? I'm doing the intersection of 2 planes right now, and I was just wondering if you had 2 cartesian eq'ns say 5x+2y+7z+1=0 and 5x-6y+8z-1=0, if you minus the 2 equations you'll have eliminated x, and you'll get a line equation with only y and z as the variables. I'm just trying to get a visual idea of what's going on when you eliminate a variable from 2 cartesian equations. So originally you had two different planes, now that you subtracted one from the other, what does the new line represent? If anyone can help explain it/provide visual that would be greatly appreciated.
Mathematics news on Phys.org
The line represents where the two planes intersect.
That's what my friend was saying too, but how do you know that?
Whats the difference between eliminating, x or y or z in 2 cartesian equations and the line it creates?
You can only subtract if both equations are true. The only way both equations are true is if they intersect.
But you can still subtract them and get a solution of 0, which means they don't intersect (the 2 planes are parallel)?
Do you know what this type of math is called? I just can't seem to get my head wrapped around the subtraction of planes...maybe an animation/diagram would help? I mean, I understand 2 functions adding/subtracting because you can see the product visually and how its dependent on the 2 equations. With planes, it's harder to visualize since it's in 3d :(
Thanks for you help though!
If you subtract the two planes and get zero then they are parallel. Parallel planes don't need to intersect but in that case you won't get zero, you'll get something that doesn't make scene like 0=1. The type of math is called linear algebra. The type method is called elimination.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
