Interference - Single slit diffraction
5 replies · 4K views
Isaac Pepper
< Mentor Note -- thread moved to HH from the technical physics forums, so no HH Template is shown >[/color]
Hi guys, I have a question here which I'm struggling to do and perhaps you could help ;
Monochromatic electromagnetic radiation with wavelength λ from a distant source passes through a slit. The diffraction pattern is observed on a screen 2.50 m from the slit.
If the width of the central maximum is 6.00 mm, what is the slit width a if the wavelength is 500 nm (visible light)?
What I have done is
y=(R(m+1/2)lambda) / d where y = 3mm (half of the central maximum width); R = 2.5m m = 0 lambda=500nm
d =( R(m+1/2)lambda) / y
d =( 2.5 * (1/2) * 500x10^-9 )/ 3x10^-3
and so I manage to obtain d = 2.08x10^-4 m, however this answer is wrong
what am I doing wrong?
Thanks !
Hello Isaac, welcome to PF :smile: !
This looks an awful lot like homework, so better post it there. You get thrown in a useful template as an extra !
You sure you are applying an equation for a single slit diffraction pattern ?
Thanks ! I have worked it out and I was indeed using the 2-slit diffraction formula :/
The answer was 4.167x10^-4
Well done ! Hope to see you back some time in the future, but don't hurry...
