Interference with slits of different width
  • Level: Graduate
  • Thread starter weirdoguy
weirdoguy
Hello everyone!
So I'm working through problems from this years' polish physics olimpiad, and I have a problem with one problem (I google-translated it, hope it's not a problem):
A flat wall contains three equidistant, thin slits of identical length. The distance between adjacent slits is d = 2.116 μm. The width of the central slit is w = 1.4 times greater than the other slits. A monochromatic wave with wavelength λ = 650 nm is incident perpendicularly on the partition. Interference fringes can be observed on a screen located at a distance significantly greater than d. Determine the angle at which first interference minimum is observed.
Here is the drawing:
Diagram of three equally spaced slits in a wall lit by a plane monochromatic wave, with rays from each slit converging to a distant screen at the top; the spacing d and wavelength λ are labelled, and the angle α is marked between the central ray and the ray to the screen.
So, authors state that the intensity of wave at the point we are interested in is proportional to:
Equation: cos(2π(l − d sin α)/λ − ωt) + w cos(2π l/λ − ωt) + cos(2π(l + d sin α)/λ − ωt) = cos(2π l/λ − ωt)(w + 2 cos(2π d sin α/λ)),
My question: is there a simple, high-school argument that there should be ##w## in there, multiplying second cosine? I found something on wikipedia, but complex exponents and all that are not a good look in high-school.
I know I should know such things as a physicists, but "waves and oscillations" were at the second year, exactly at the time when I started partying hard, so I'm not that good with waves 👨‍🦽 I'm still good at partying though.
PS. Interesting that google translator changed commas to periods in numbers (we use commas in Poland, so we write 2,116 instead of 2.116).
I have learned expansion of
$$\cos(A+B),\cos(A-B),\sin(A+B),\sin(A-B)$$
in high school math.
Let w=0, d=0 in the formula we get 2 which corresponds to width of a synthesized single slit.
Let w=1, d=0, we get 3 which again corresponds to width of a single slit.
We deduce that width of a slit is coefficient for passing wave.
weirdoguy said:
My question: is there a simple, high-school argument that there should be w in there, multiplying second cosine?
Is it not basically treating the three slits as point sources (ok in the Fraunhofer regime), and making the amplitude from the central slit ##w## times higher because it lets through ##w## times more light?
  • Love
Ibix said:
making the amplitude from the central slit w times higher because it lets through w times more light?
Ok, I thought about it, but I felt that there is something more to that. Thanks! :oldbiggrin:
