Interpretation of Derivative of Metric = 0 in GR - Learning from Wald
The discussion centers on the interpretation of the covariant derivative of the metric tensor in General Relativity (GR), specifically referencing Wald's approach. It is established that the covariant derivative of the metric tensor equals zero, which does not imply that the metric tensor is constant throughout spacetime or that curvature is constant. The unique connection chosen preserves inner products of parallel-transported vectors, leading to a zero derivative of the metric tensor. This indicates that the covariant derivative is designed to measure changes relative to the metric itself, filtering out changes due to the geometry of spacetime.
  • Understanding of General Relativity (GR) principles
  • Familiarity with covariant derivatives and tensor calculus
  • Knowledge of metric tensors and their properties
  • Basic concepts of curvature in Riemannian geometry
  • Study Wald's "General Relativity" for a deeper understanding of metric tensors
  • Explore Lee's "Riemannian Manifolds" for insights on affine connections and their relationship to metrics
  • Learn about the Riemann and Ricci tensors to understand their role in curvature
  • Research the implications of covariant derivatives in different geometrical contexts
Students and researchers in theoretical physics, mathematicians specializing in differential geometry, and anyone seeking to deepen their understanding of General Relativity and its mathematical foundations.
LarryL
I am trying to learn GR, primarily from Wald. I understand that, given a metric, a unique covariant
derivative is picked out which preserves inner products of vectors which are parallel transported.
What I don't understand is the interpretation of the fact that, using this definition of the derivative,
the covariant derivative of the metric tensor = 0.
In my mind, the covariant derivative applied to any tensor is telling us something about
how the tensor changes from point to point.
Isn't saying that the covariant derivative of the metric tensor = 0 (everywhere, correct?) the same thing
as saying the metric tensor is "constant" (in some sense) throughout spacetime?
But, of course, it does not have to be constant. And wouldn't that imply constant curvature
(or zero curvature) everywhere? This, of course, must be a wrong interpretation (and Riemann and Ricci
tensors are clearly nonzero, and they more directly relate to curvature).
So what is wrong with my interpretation of a derivative as a measure of change?
thanks.
This stack exchange answer casts some light on it. The derivative is chosen from amongst the many available connections as the (provably unique) connection that gives zero when applied to the metric. Preserving inner products of parallel-transported vectors - the officially stated criterion for selection of the connection - is mathematically equivalent to preserving the metric.
As you observe, the constancy of the derivative at zero does not entail constant curvature, because the metric tensor is not itself a curvature tensor.
In the approach described on stack exchange the derivative is selected based on the metric. But it can also be done the other way around. IIRC, Lee does that in his book 'Riemannian Manifolds'. He defines various types of connection and then says that, given an affine connection on a manifold, a Riemannian metric is the unique symmetric 2-tensor that has a certain property in relation to the connection. I don't have the book here right now, so don't remember the property, but it's probably equivalent to giving a zero derivative of the tensor.
Here's another hokey, folksy way of looking at it, that may or may not mean anything or have any validity: using a connection to differentiate a tensor is - in a very loose sense - measuring the rate of change of the tensor field relative to the connection. But since there is a unique relation between affine connections and their corresponding metric tensors, we could say that differentiating the metric is measuring the rate of change of the tensor field relative to itself. And that is something that one might intuitively expect to be zero.
LarryL said:
Isn't saying that the covariant derivative of the metric tensor = 0 (everywhere, correct?) the same thing as saying the metric tensor is "constant" (in some sense) throughout spacetime?
No. One way to look at it, heuristically, is that the point of the covariant derivative is to tell how a vector or tensor changes "relative to the metric"; i.e., it is intended to filter out changes that are due to the way the geometry of spacetime changes, and focus on changes that are due to the way the vector or tensor itself changes. But of course all changes in the metric tensor are changes in the way the geometry of spacetime changes, so if you filter out those changes, you're left with zero change.
  • · Replies 20 ·
  • · Replies 26 ·
  • · Replies 19 ·
