Interpreting Matlab function simp
  • Topic: MATLAB
  • Thread starter Thread starter Ein Krieger
    Function Matlab
7 replies · 3K views
Ein Krieger
Hello, guys
Hey guys,
Got stuck with function integration using Simpson's rule and need your help.
Please first refer to picture attached for full idea of my question:
The Matlab command related to it is:
for i=1:nr
u1d(i)=4.0*pi*r(i)^2*u(it,i)
end
I1=simp(0.0,r0,nr,u1d)/(4.0/3.0*pi*r0^3)
I1 is
nr=21
r0=1.0;
Does it mean that I1 is integrated 21 times between boundaries 0 and r0?
Can you post more information? The code you posted references variables that you never define. Make it so that your code block can be copy/pasted into matlab.
Yes. Sure
I have attached all commands with order from Pic.1 to Pic.3
simp() is not a MATLAB function, so the information about the input arguments is not available in the documentation. I suggest looking at the function file for simp() to find this info.
EDIT: I found information about this function in the MATLAB file exchange.
Code:
function s = simp(f, a, b, h)
x1 = a + 2 * h : 2 * h : b - 2 * h;
sum1 = sum(feval(f, x1));
x2 = a + h : 2 * h : b - h;
sum2 = sum(feval(f, x2));
s = h / 3 * (feval(f, a) + feval(f, b) + ...
           2 * sum1 + 4 * sum2);
It appears that the inputs are:
f=function, a=initial value, b=end value, h=interval size
I have found it as separate m.file. Here are the commands:
function uint=simp(xl,xu,n,u)
h=(xu-xl)/(n-1);
uint(1)=u(1)-u(n);
for i=3:2:n
uint(1)=uint(1)+4.0*u(i-1)+2.0*u(i);
end
uint=h/3.0*uint;
But why here different variables are used such as xl and xu?
It seems to me that we use r in integration?
At a glance it looks like
xl = beginning of interval
xu = end of interval
n = number of slices
u = function
So in your case of
Code:
You are integrating u1d from 0 to r0 with nr intervals
u = function
So in your case of
Code:
So you mean simp can be uniformly used for every type of variable assuming their correct order?
