Intuition behind elementary operations on matrices
The discussion revolves around the intuition and principles behind elementary operations on matrices, particularly in the context of finding the inverse of a matrix. Participants explore the validity and implications of various row operations, questioning why certain operations preserve equivalence while others do not. The scope includes theoretical reasoning and conceptual clarification regarding matrix equations and operations.
  • Some participants inquire about the underlying principles that justify the use of elementary row operations in matrix equations.
  • There is a discussion on the validity of specific operations, such as replacing a row with another row or performing combinations of rows, and whether these yield equivalent equations.
  • One participant suggests that adding or subtracting the same number from both sides of a matrix equation can transform it into another equation, but questions arise about when this is appropriate.
  • Concerns are raised about operations like replacing a row with a linear combination of other rows and whether such operations are valid elementary row operations.
  • Some participants express confusion about the distinction between "equivalent equations" and "equalities" in the context of matrix operations.
  • There is mention of elementary matrices and their relationship to elementary row operations, with some participants indicating a lack of familiarity with this concept.
Participants do not reach a consensus on the validity of certain row operations, with some arguing that specific operations do not yield equivalent equations while others assert that they do. The discussion remains unresolved regarding the criteria for valid elementary row operations.
Participants highlight limitations in understanding the definitions and implications of various operations, as well as the need for clarity on what constitutes an equivalent equation versus an equality.
  • #31
Mr Real said:
I know they are not the same but that's not what I had asked. What I had asked is: if we've an equality C = (F)(G) and we apply elementary row operation on both sides then the new RHS will be different from C and the LHS will be different from (F)(G) but RHS will be still be equal to LHS, that is we would get the same transformation on both sides even after applying an elementary operation.
The only three operations that preserve the solution set are : exchange rows, scaling (by a non-zero constant) , adding a multiple of one row to another. It is an interesting exercise to show these are the unique operations with these properties.
  • #32
PeroK said:
I'll let you find your own counterexample to that. Hint: think about the identity matrix.
But, if you think for a moment about matrix multiplication you will see that there is no way that row operations would support that sort of result.
I don't know what you mean. If I consider the equality A = (I)(A) and then we apply any elementary row operation on both sides, which is equivalent to multiplying by an elementary matrix (let's say B), then the equality will become; (B)(A) = (B)(I)(A), this new equality is different from the previous one but we still have an equality, that is the transformations we have obtained now are different from the previous ones but are equal to each other. This is what I've been trying to say and I think it is correct.
  • #33
If you are talking about applying the row operation to the first matrix on the RHS, then the proof is trivial - effectively what you have done. I assumed you were talking about applying the row operations to all matrices.
In any case, I can't see where this is leading.
  • #34
Sorry, I forgot one thing: when we were considering matrices as a set of equations and considering equalities consisting of matrices, not only did we obtain an another equality when we did the valid elementary operations but the solutions to these matrices was the same as the solutions to the previous equalities. Is this what I've been missing here, that it doesn't matter if we have got another equality after applying the elementary operation, instead the thing that matters is we didn't get the previous transformation?
Another doubt: Then, do elementary operations have no meaning when we consider matrices as linear transformations?
  • #35
Elementary operations are themselves linear transformations.
  • #36
My question is: Then how will you explain operations like changing R2 to R1-R3 not working for matrices in context of linear transformations. Have I made myself clear this time? I have understood why some operations like changing R2 to R2+R3 work for matrices while some other operations like changing R2 to R1+R3 don't, in context of a system of equations, now how does one explain all this in context of linear transformations?
  • #37
Your question reveals a confusion of ideas that makes it hard to address directly. There is no reason that a technique appropriate to the manipulation of equations should have the specific effect you seem to demand.
The mathematics is clear. An equation of the form ##A = BC## is not preserved if all three matrices are subject to the same row operation.
A simple counterexample can easily be found and that should end the debate.
A system of linear equations does have the same solutions if the matrix representing them is subject to a row operation. That has been essentially proved in this thread. That too should end the debate.
Moreover, the proof and counterexamples provide all the reasons you need to understand why.
That is mathematics and there is nothing more to be said.
  • #38
PeroK said:
The mathematics is clear. An equation of the form ##A = BC## is not preserved if all three matrices are subject to the same operation.
Oh, I think this is the source of much of the confusion, because I didn't ever say or imply that all three matrices are subject to the same operation, I only talked about applying the operation in the RHS as well as the LHS, but since there are two matrices in the LHS, maybe you thought I was talking about changing both of them, when in fact I was talking only about one.
Now can you tell me why for an equality; C = (F)(G), some operations, like changing R2 to R2+R3 work while some other operations like changing R2 to R1+R3 don't, in context of linear transformations?(I have understood the reasons for this when we take matrices to be a system of equations)
  • #39
In particular, you need to talk about applying the row operation only the first factor in a RHS that is a product of matrices ( rather than being something like FG + H)
Again, we must define what it means for something to "work".
For example, the linear transformation given by:
##x_{new} = 2 x_{old} + 3 y_{old},##
##y_{new} = x_{old} - y_{old}##
defines a transformation (i.e. a function) that maps coordinates ##(x_{old},y_{old})## to coordinates ##(x_{new},y_{new})##. There no overt notion of solving for anything in the definition of a linear transformation.
However, we can think a "solutions" to the linear transformation as being quadruples of numbers of the form ##(x_{new},y_{new},x_{old},y_{old})## (such as (5,0, 1,1) in the example) where the second pair of numbers is the result of applying the linear transformation to the first pair of numbers. From this point of view, not all quadruples of numbers are solutions. For example (1,2,3,4) is not a solution to the example.
Taking that point of view, two linear transformations are "equivalent" when they have the same set of solutions.
Since your question involves 3 rows, we must look at an example of a linear transformation like:
##\begin{pmatrix} x_{new}\\ y_{new}\\ z_{new} \end{pmatrix} = \begin{pmatrix}3&1&1\\0&1&0 \\2&0&5\end{pmatrix} \begin{pmatrix} x_{old}\\y_{old}\\z_{old} \end{pmatrix} ##
This matrix equation can be interpreted as 3 linear equations (in 6 variables) that define the linear transformation:
eq. 1) ##x_{new} = 3x_{old} + y_{old} + z_{old}##
eq. 2) ##y_{new} = y_{old}##
eq. 3) ##z_{new} = 2x_{old} + 5 z_{old}##
(When people say that a matrix "is" a linear transformation, they mean that you can supply variables to form a matrix equation like the one above.)The customary way to write a system of equations is to put all the variables on the left hand side, but we don't need to do that for our purposes.
We have 3 equations in 6 unknowns, so we expect the system to have an infinite number of solutions. However, having an infinite number of solutions does not imply that any arbitrary sextuple of numbers will be one of those solutions.
Suppose we do the operation "Replace row 2 by the sum of row 1 and row 3". That's like erasing eq 2.) and putting the sum of equation 1) and equation 3) in its place. Would you expect that operation to preserve the solutions to the system of equations? It removes all information about ##y_{new}## and replaces it with an equation that is just a consequence of eq. 1) and eq. 3).
  • #40
Took me some time to understand it but yes, replacing row 2 by the sum of row 1 and row 3 will change the solutions. Thanks for replying. But then how will the solutions be preserved if we replace row 2 by the sum of row 2 and row 3.
Thanks!
Mr R
  • #41
That procedure could be reversed by subtracting row 3 from the modified row 2.
It would require some work to write a formal proof of which row operations preserve solutions, but the intuitive idea is that operations that can be reversed do not lose or add information to requirements set by the original set of equations.
  • #42
Thank you very much for clearing my doubts so well again. I think I need to personally practise more questions first to really grasp the concepts. Can you please suggest some references(websites, channels, etc.) for class 12 maths (for getting the intuition and solving problems too).
Thanks
Mr R
  • #43
I haven't been a math student or teacher for over 20 years, so I'm not familiar what's available. Other forum members probably are.
  • #44
Thank you all the same.
:bow:
Mr R
  • #45
Stephen Tashi said:
With an equation in real variables, you can multiply both sides by the same number. For example, we can transform the equation ##0 = (x/7 - 1/7)(x-2)## to an equivalent equation by multiplying both sides by ##7##. When we multiply the right side by 7, we are permitted to multiply only the factor ##(x/7 - 1/7)## by 7. By analogy, if we have the matrix equation ##C = (F)(G)## we can multiply both sides of the equation by a matrix ##E##, obtaining an equivalent equation ##(E)(C) = (E)(F)(G)##. In evaluating the right hand side, we can compute it as ##(EF)(G)##
@Stephen Tashi, sorry to bother you but I had a doubt regarding this. You said here that in the equation 0 = (x/7 - 1/7)(x - 2), if we want to convert this equation to an equivalent equation by multiplying both sides by 7, then in the RHS we are only allowed to multiply the factor (x/7 - 1/7) by 7, but I don't see why we can't multiply the factor (x-2) instead,
As far as I can see (x/7 - 1/7)(7x - 14) = 0 and (x - 1)(x - 2) = 0 both have the same solutions as (x/7 - 1/7)(x - 2), i.e. x = 1,2.
Please can you clear my confusion?
Mr R
  • #46
I think you mean "why we can't multiply the factor (x-2) by 7 instead". We can do that. The point is that we can only multiply one of the two factors by 7.
  • #47
Stephen Tashi said:
I think you mean "why we can't multiply the factor (x-2) by 7 instead". We can do that. The point is that we c9an only multiply one of the two factors by 7.
But you had used this example as an analogy to help me understand that if we have an equality (C) = (F)(G), and we multiply this equality by an elementary matrix E on both sides to get an equivalent equality, then in the RHS, we'll get (E)(F)(G) and we'll evaluate it as (EF)(G); so, considering what you said now, Can the RHS also be evaluated as (E)(FG) to get the same equivalent equality which we get when we evaluate it as (EF)(G)?
Thanks so much
Mr R
  • #48
The equation (C)(E) = (F)(G)(E) will be equivalent to the the equation C = (F)(G) and also to the equation (E)(C) = (E)(F)(G) when E is an elementary matrix, but the equation (C)(E) = (F)(G)(E) need not be exactly the same equation as the equation (E)(C) = (E)(F)(G) when the matrix multiplications are worked out because, in general, (E)(C) is not equal to (C)(E).
For example, consider the elementary matrix ##E = \begin{pmatrix} 0&1\\ 1& 0 \end{pmatrix} ## and the matrix ##C = \begin{pmatrix} r & s \\ t & u \end{pmatrix} ##
##(E)(C) = \begin{pmatrix} t & u \\ r & s \end{pmatrix}##
## (C)(E) = \begin{pmatrix} s & r \\ u & t \end{pmatrix}##
Multiplying C on the left by E performs the row operation of interchanging the two rows of C.
Multiplying C on the right by E performs the column operation of interchanging the two columns of C.
  • #49
Okay, now I am clear with this. Thanks, for clearing my doubts again! :oldsmile:
Mr R
9K
  • · Replies 25 ·
