Graduate How Is the Anticommutator Derived in SU(3) Algebra?
The derivation of the anticommutator in SU(3) algebra is established using the normalization condition for the generators, specifically ##[\lambda_i, \lambda_j] = 2if_{ijk}\lambda_k##. The anticommutator is expressed as $$\left\{\lambda_i, \lambda_j\right\} = \frac{4}{3}\delta_{ij} + 2d_{ijk}\lambda_k$$, where ##d_{ijk}## represents the symmetric invariant tensor. The discussion highlights the importance of understanding the traces of the generators and their normalization, particularly ##\text{Tr}(\lambda_i \lambda_j) = 2\delta_{ij}##, which is crucial for deriving the quadratic Casimir of the representation.
  • Understanding of SU(3) algebra and its generators
  • Familiarity with Lie algebra structure constants, specifically ##f_{ijk}##
  • Knowledge of invariant tensors in group theory, particularly ##\delta_{ij}## and ##d_{ijk}##
  • Basic concepts of trace operations in linear algebra and their application in quantum mechanics
  • Study the derivation of the quadratic Casimir operator for SU(3) representations
  • Learn about the properties and applications of invariant tensors in Lie algebras
  • Explore the normalization conventions for generators in different Lie groups
  • Investigate the role of the Dynkin index in the context of irreducible representations
The discussion is beneficial for theoretical physicists, mathematicians specializing in group theory, and graduate students studying quantum mechanics or particle physics, particularly those focusing on gauge theories and symmetry groups.
CAF123
'Using the following normalization in the su(3) algebra ##[\lambda_i, \lambda_j] = 2if_{ijk}\lambda_k##, we see that ##g_{ij} = 4f_{ikl}f_{jkl} = 12 \delta_{ij}## and, by expanding the anticommutator in invariant tensors, we have further that $$\left\{\lambda_i, \lambda_j\right\} = \frac{4}{3}\delta_{ij} + 2d_{ijk}\lambda_k.$$
The first statement about ##g_{ij}## I understand but how did the one about the anticommutator come about?
I can reexpress ##\left\{\lambda_i, \lambda_j\right\} = [\lambda_i, \lambda_j] + 2 \lambda_j \lambda_i = 2if_{ijk}\lambda_k + 2 \lambda_j \lambda_i##. Now, ##\lambda_j \lambda_i## is a second rank tensor so can be written as ##a \delta_{ij}##, for some a. I was thinking I could then consider a single case to determine a (i.e i=j=1) but this didn't work.
Any tips would be great!
Thanks!
You are incorrect to say that ##\lambda_j \lambda_i## can be written as ##a \delta_{i j}##, which explains why your approach didn't work. Unfortunately, I don't know how to prove your identity. What is ##d_{i j k}##?
Hi Jackadsa,
Yup, I saw that I was incorrect in that after I posted my thread. ##\delta_{ij}## and ##d_{ijk}## are supposed to be the two invariant tensors for SU(3). In my notes it also says that ##d_{ijk} = \frac{1}{4}\text{Tr} \lambda_i \left\{\lambda_j, \lambda_k\right\}##, so I guess I can use this fact. So then $$d_{ijk} = \frac{1}{4}\text{Tr} \lambda_i ([\lambda_j, \lambda_k] + 2 \lambda_k \lambda_{\ell}) = \frac{1}{4} \text{Tr} \lambda_i (2if_{jk \ell }\lambda_{\ell} + 2 \lambda_k \lambda_{j}) = \frac{i}{2} f_{jk\ell}\text{Tr} \lambda_i \lambda_{\ell} + \frac{1}{2}\text{Tr} (\lambda_i \lambda_k \lambda_j)$$ using the given normalisation of the algebra. Any ideas how to continue?
Thanks!
Any n \times n hermitian matrix M can be expanded in terms of the n \times n hermitian traceless matrices \lambda^{a} , a = 1,2, \cdots , n^{2}-1, and the n \times n identity matrix I_{n} as follow
<br /> M = \frac{1}{n} \mbox{Tr}(M) \ I_{n} + \frac{1}{2} \sum_{c=1}^{n^{2}-1} \mbox{Tr}(M \lambda^{c}) \ \lambda^{c} . \ \ \ (1)<br />
Now, take M = \{ \lambda^{a} \ , \lambda^{b} \} and define the symmetric invariant tensor
d^{abc} \equiv \frac{1}{4}\mbox{Tr}\left( \{ \lambda^{a} \ , \lambda^{b} \} \lambda^{c} \right) . With the \lambda’s normalized according to \mbox{Tr}(\lambda^{a}\lambda^{b}) = 2 \delta^{ab}, equation (1) becomes
\{\lambda^{a} , \lambda^{b} \} = \frac{4}{n} \delta^{ab} \ I_{n} + 2 d^{abc} \lambda^{c} .
Adding this to the algebra [\lambda^{a} , \lambda^{b}] = 2 i f^{abc} \lambda^{c}, and multiplying by another \lambda, you get
\lambda^{a} \lambda^{b} \lambda^{e} = \frac{2}{n} \delta^{ab} \lambda^{e} + (i f^{abc} + d^{abc} ) \ \lambda^{c} \lambda^{e} . Taking the trace, you get
\frac{1}{2} \mbox{Tr} (\lambda^{a} \lambda^{b} \lambda^{c}) = i f^{abc} + d^{abc} .
Likes CAF123
Hi samalkhaiat,
samalkhaiat said:
... With the \lambda’s normalized according to \mbox{Tr}(\lambda^{a}\lambda^{b}) = 2 \delta^{ab}...
I see, thanks. The only thing I didn't understand was this statement above^^. In general for any irreducible representation we have that ##\text{Tr}T_a T_b = C(R) \delta_{ab}## where ##C(R)## is the Casimir of the representation. In this case, the ##\lambda_a## constitute the fundamental representation for SU(3) so are indeed irreducible. I am just not sure how to get ##\text{Tr}\lambda_i \lambda_j = 2\delta_{ij}##, i.e showing the casimir of the defining rep of SU(3) is 2. Any ideas on this?
I think I could also obtain the result by writing ##\left\{\lambda_i, \lambda_j\right\} = a\delta_{ij} + b d_{ijk}\lambda_k##, which computing some traces gives me a and b.
Thanks.
Don’t confuse normalization (i.e., orthogonal transformation plus scalling) of generators with the Dynkin’s index of irreducible representations.
The quadratic Casmir of Lie algebra is given by
C_{2}(r) = g^{ab} \ t^{(r)}_{a} \ t^{(r)}_{b} = d_{(r)} \ I_{r} where d_{r} is a representation-dependent number called the Dynkin’s index, and I_{r} is the identity matrix in the irreducible representation, i.e., \mbox{Tr}(I_{r}) is the dimension of the representation space \mbox{dim}(r). Taking the trace, you get g^{ab} \ \mbox{Tr}(t^{(r)}_{a} \ t^{(r)}_{b}) = d_{(r)} \ \mbox{dim}(r) . In the Adjoint representation, you can normalize the generators A_{a} so that \mbox{Tr}(A_{a} \ A_{b}) = g_{ab}. So, for any Lie algebra you have g^{ab} \ g_{ab} = d_{A} \ \mbox{dim}(A) , \ \ \Rightarrow \ \ d_{A} = 1. This is because g^{ab}g_{ab} = \delta^{c}_{c} = \mbox{dim}(A).
For SU(n) and SO(n) you can always make the following normalization convention \mbox{Tr}(T_{i} \ T_{j}) = \lambda \ \delta_{ij}, because \mbox{Tr}(T_{i} \ T_{j}) is a real symmetric matrix and can be diagonalized by taking an appropriate real linear combination of the generators, with diagonal coefficients set to a constant \lambda. With this basis of the algebra, the structure constants are given by C^{k}_{mn} = - \frac{i}{\lambda} \ \mbox{Tr}(T_{k}[T_{m},T_{n}]) , which implies that C^{k}_{mn} is totally antisymmetric in all three indices.
For example SU(2), where g^{ab}= \frac{1}{2}\delta^{ab}, we choose, for the Fundamental representation, \mbox{Tr}(T_{a}^{(F)} \ T_{b}^{(F)}) = \mbox{Tr}( \frac{\sigma_{a}}{2} \ \frac{\sigma_{b}}{2} )= \frac{1}{2} \ \delta_{ab} , So, d_{(F)} \ \mbox{dim}(F) = \frac{1}{2} \ \delta^{ab} \ \frac{1}{2} \ \delta_{ab} = \frac{3}{4} . From this we find the Dynkin’s index d_{(F)} = \frac{3}{8}, because \mbox{dim}(F) = 2.
  • · Replies 38 ·
