Inverse Laplace transform of 1/(s²+1)²
5 replies · 8K views
nito18
Hi.
I need help to resolve the inverse laplace transform of {1/((x^2)+1)^2}2. The attempt at a solution
I have tried to do:
{(1/((x^2)+1) * (1/((x^2)+1)}
then, convolution, sen x
But, isn't working
Thanks for your help :)
nito18 said:
Hi.
I have tried to do:
But, isn't working
Using usual notation you would use ##s## as the variable in transform space:$$
\mathcal L^{-1}\frac 1 {(s^2+1)^2}$$Forum rules require you to show some effort. So what did you get for$$
\mathcal L^{-1}\frac 1 {s^2+1}\text{?}$$Then show us what your convolution integral looks like and where you are stuck.
yes, sorry. is:
so
\mathcal L^{-1}\frac 1 {(s^2+1)} * \frac 1 {(s^2+1) }$$
then
f(τ) = sen τ
g(t-τ) = sen (t-τ)
∫ sen τ * sen (t-τ) dτ
Integration by parts
u= sen (t-τ)
du = -cos(t-τ)
dv= sen τ dτ
v= -cos τ
∫ sen τ * sen (t-τ) dτ = u= -(sen (t-τ) * cos τ) - ∫ cos τ * cos(t-τ)
Integration by parts, again... not working
maybe, another theorem... I don't know
use a trig "difference formula": [itex]sin(t- \tau)= sin(t)cos(\tau)- cos(t)sin(\tau)[/itex] so that your integral becomes
[tex]\int sin(\tau)sin(t- \tau) d\tau= \int sin(\tau)[cos(\tau)sin(\tau)- cos(t)sin(\tau)]d\tau[/tex]
[tex]= sin(t)\int sin(\tau)cos(\tau) d\tau- cos(t)\int sin^2(\tau)d\tau[/tex]
nito18 said:
yes, sorry. is:
so
Since Halls has already responded to your problem, I will just point out that the above isn't what you mean. You take the convolution after the inverse, so you want$$
\mathcal L^{-1}\frac 1 {(s^2+1)} * \mathcal L^{-1}\frac 1 {(s^2+1) }$$
