Inverse Laplace transform Signals and systems
4 replies · 3K views · last reply
mattbrrtt
Compute Y(t).
Y(s)= (s(2s+11)+ω(8s+4ω^2))/((s^2+ω^2)(s+9)(s+2))
(s(2s+11)+ω(8s+4ω^2 ))/((s^2+ω^2)(s+9)(s+2))= A/(s^2+ω^2 )+B/(s+9)+C/(s+2)
Every example I have looked at does not have the ω variable, but I am not sure that is the problem.
This is a problem from a lab for a signals and systems course. The problem starts by giving h(t) =[cos 2t + 4 sin 2t]u(t), and asking for the impulse response. Then an input of x(t) = (5/7)(e^-t)-(12/7)(e^-8t) is provided. The output response is then calculated, and that is where this question picks up.
Thank you for any assistance.
Matt
The numerator of the first fraction should be of the form As+B because the denominator is a quadratic.
I assume X(s) and H(s) are supposed to be the Laplace transforms for the given x(t) and h(t). If so, you need to recalculate X(s) as it isn't correct.
ω is a constant. It's the frequency in the cosine and sine terms, so you can set it to 2 in H(s).
I am guessing that the mistake made with the X(s) and H(s) terms is that I simplified and ended up with unfavorable numerators. I am going to try using :
H(s)=1/(s+ω^2 )+4/(s^2+ω)
X(s)=1/(s+2)+1/(s+9)
and calculate from there.
Is this correct?
Thank you.
Is this correct?
I edited my first post a couple of times after I first submitted it, so you may want to reread it.
Your original H(s) was correct. You just have to set ω=2. It's the angular frequency which appears in the terms of x(t).
X(s), however, remains a mystery. I'm not sure how you're getting 1/(s+2) and 1/(s+9) terms in it.
It turns out if you get X(s) and H(s) correct, the algebra simplifies a lot, and you should find it relatively easy to find y(t).
Thanks.
The X(s) comes from the formula that was given in the assignment.
x(t)=(5/7)(e^-t)-(12/7)(e^-8t)
When I was writing my explanation, I think I found an error. I will post back.
