Inverse Laplace Transform with Division and Integration
_N3WTON_
Division by s Equals integration by t:
For this problem use the following property (see relevant equations) to find the inverse transform of the given function: [itex]F(s) = \frac{1}{s(s-1)}[/itex]
[itex]L^{-1}(\frac{F(s)}{s}) = \int_{0}^{t} f(\tau)\,d \tau[/itex]
Using the above formula I have: [itex]F(s) = \frac{1}{s(s-1)}[/itex]
So : [itex]\frac{F(s)}{s} = \frac{\frac{1}{s(s-1)}}{s} = \frac{1}{s^{2}(s-1)}[/itex]
Next I used a partial fraction decomposition:
[itex]\frac{1}{s^{2}(s-1)} = \frac{A}{s} + \frac{B}{s^{2}} + \frac{C}{(s-1)}[/itex]
[itex]As(s-1) + B(s-1) + Cs^{2} = 1[/itex]
Solving for A, B, and C I found [itex]A=-1 \hspace{1 mm} B=-1 \hspace{1 mm} C = 1[/itex]
So the decomposition is:
[itex]\frac{1}{s^{2}(s-1)} = -\frac{1}{s} - \frac{1}{s^{2}} + \frac{1}{(s-1)}[/itex]
The inverse Laplace transform of the above equation is:
[itex]-t - e^{t} - 1[/itex]
However, the answer given in my textbook is:
[itex]e^{t} - 1[/itex]
Coincidentally, when I perform the partial fraction decomposition on [itex]F(s)[/itex], I arrive at the answer given in the back of the text, which is really confusing me, do I not need to divide [itex]F(s)[/itex] by [itex]s[/itex]?
[itex]L^{-1}(F(s)) = \int_{0}^{t} f(\tau)\,d \tau[/itex]
You have stated the formula wrong. The formula you want is$$
\mathcal L^{-1}\frac 1 s F(s) = \int_0^t f(\tau)~d\tau$$where ##f## is the inverse of ##F##. In your problem ##F(s) =\frac 1 {s-1}##. Informally, this says if you suppress a factor of ##\frac 1 s## you must integrate the result to get the original inverse.
ah, thank you very much, the problem makes much more sense now. I am blaming my book though, the formula they provided isn't very clear, they formatted it in the same way that I did above...although to be fair I guess I just completely misinterpreted the problem :)
