Understanding the Inverse of Jacobian Matrices: A Brief Overview
The discussion centers on the properties and relationships of Jacobian matrices in the context of partial differentiation. A key point raised is the confusion regarding the equation involving the determinants of matrices A and B, where the implication that their product equals -1 is questioned. The participants explore the chain rule and its implications, particularly addressing the relationship between partial derivatives and the independence of variables. A clarification is made that the relation \(\frac{\partial x}{\partial u} = \left(\frac{\partial u}{\partial x}\right)^{-1}\) does not universally hold, especially in non-linear coordinate systems. The conversation concludes with an example illustrating the conditions under which the derivatives align correctly.
parsesnip
I want to prove that ##\left| \frac{\partial(x,y)}{\partial(u,v)} \right|=\frac{1}{\left|\frac{\partial(u,v)}{\partial(x,y)}\right|}## (If this is true)
##\frac{\partial(x,y)}{\partial(u,v)}=\begin{vmatrix} x_u & x_v\\ y_u&y_v \end {vmatrix}##
##\frac{\partial(u,v)}{\partial(x,y)}=\begin{vmatrix} u_x & u_y\\ v_x&v_y \end {vmatrix}##
I got that ##{x_u}{y_v}-{x_y}{y_u}=####\frac{1}{\frac{1}{{x_u}{y_v}}-\frac{1}{{y_u}{x_v}}}##. But this implies that ##{x_u}{x_v}{y_u}{y_v}=-1## and I don't see how that is true?
Very simple case of u=x, v=y obviously the statement stands. but
x_u x_v y_u y_v = 1*0*0*1=0
So your result seems wrong.
Find 2X2 matrices A, B by partial differentiation
<br /> \begin{pmatrix}<br /> du \\<br /> dv \\<br /> \end{pmatrix}<br /> <br /> = A<br /> <br /> \begin{pmatrix}<br /> dx \\<br /> dy \\<br /> \end{pmatrix}
<br /> \begin{pmatrix}<br /> dx \\<br /> dy \\<br /> \end{pmatrix}<br /> <br /> = B<br /> <br /> \begin{pmatrix}<br /> du \\<br /> dv \\<br /> \end{pmatrix}
So
AB=BA=E
det\ A\ \ det\ B = 1
Likes parsesnip
By the chain rule <br /> 1 = \frac{\partial x}{\partial x} = \frac{\partial x}{\partial u}\frac{\partial u}{\partial x} + \frac{\partial x}{\partial v}\frac{\partial v}{\partial x} and <br /> 0 = \frac{\partial y}{\partial x} = \frac{\partial y}{\partial u}\frac{\partial u}{\partial x} + \frac{\partial y}{\partial v}\frac{\partial v}{\partial x} and similarly \frac{\partial y}{\partial y} = 1 and \frac{\partial x}{\partial y} = 0. Now I suspect that if you expand <br /> 1 = \frac{\partial x}{\partial x}\frac{\partial y}{\partial y} - \frac{\partial y}{\partial x}\frac{\partial x}{\partial y} and rearrange it then you will obtain your result.
Likes parsesnip and etotheipi
I think I understand. But if ##\frac {\partial x}{\partial u}=\frac{1}{\frac {\partial u}{\partial x}}##, then doesn't ##\frac {\partial x}{\partial u}\frac {\partial u}{\partial x}=1##? Then how do you resolve the contradiction that ##1 = \frac{\partial x}{\partial x} = \frac{\partial x}{\partial u}\frac{\partial u}{\partial x} + \frac{\partial x}{\partial v}\frac{\partial v}{\partial x} = 2##?
The relation \frac{\partial x}{\partial u} = \left(\frac{\partial u}{\partial x}\right)^{-1} does not hold in general. For example, with plane polar coordinates we have \frac{\partial r}{\partial x} = \frac xr and \frac{\partial x}{\partial r} = \cos \theta = \frac xr \neq \frac rx.
Rather, if that relation does hold then it implies that x is independent of v so that \frac{\partial x}{\partial v} = 0.
Further to my post #2
A=<br /> \begin{pmatrix}<br /> u_x &amp; u_y \\<br /> v_x &amp; v_y \\<br /> \end{pmatrix}
B=<br /> \begin{pmatrix}<br /> x_u &amp; x_v \\<br /> y_u &amp; y_v \\<br /> \end{pmatrix}
AB=<br /> \begin{pmatrix}<br /> u_x &amp; u_y \\<br /> v_x &amp; v_y \\<br /> \end{pmatrix}<br /> \begin{pmatrix}<br /> x_u &amp; x_v \\<br /> y_u &amp; y_v \\<br /> \end{pmatrix}<br /> =<br /> \begin{pmatrix}<br /> 1 &amp; 0 \\<br /> 0 &amp; 1 \\<br /> \end{pmatrix}
It meets with post #3.
A=B^{-1}
<br /> \begin{pmatrix}<br /> u_x &amp; u_y \\<br /> v_x &amp; v_y \\<br /> \end{pmatrix}<br /> =\frac{1}{x_uy_v-x_vy_u}<br /> \begin{pmatrix}<br /> y_v &amp; -x_v \\<br /> -y_u &amp; x_u \\<br /> \end{pmatrix}
For an example (1,1) component says
u_x=\frac{1}{x_uy_v-x_vy_u}y_v
You see in order ##u_x =\frac{1}{x_u}## as you expect, ##x_vy_u=0 ## and ##y_v \neq 0## is required.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 31 ·
