Iodine Adsorption and Titration with Na2S2O3
  • Thread starter Thread starter charlie05
    Titration
The discussion focuses on the iodine adsorption process using activated carbon (AC) and the subsequent titration with sodium thiosulfate (Na2S2O3) to determine iodine concentration. A stock iodine solution was prepared by dissolving 2.5424 g of I2 and 24.1525 g of KI in 100 ml of water, resulting in a concentration of 117.7 g/dm3 I2. The titration revealed an equilibrium iodine concentration of 0.0544 mol/dm3 I2, with 14.5 ml of 0.075 mol/dm3 Na2S2O3 consumed, indicating the amount of iodine adsorbed on the AC surface can be calculated using the difference between the original and equilibrium iodine concentrations.
  • Understanding of iodine chemistry and its reactions.
  • Familiarity with titration techniques and calculations.
  • Knowledge of activated carbon properties and adsorption principles.
  • Basic grasp of molarity and concentration calculations.
  • Research the principles of adsorption isotherms and their applications in activated carbon.
  • Learn about the preparation and standardization of sodium thiosulfate solutions for titration.
  • Explore the calculation of specific surface area using iodine number and BET theory.
  • Investigate the role of potassium iodide (KI) in enhancing iodine solubility in aqueous solutions.
Chemists, environmental scientists, and researchers involved in adsorption studies, particularly those focusing on iodine and activated carbon applications.
charlie05
1/ iodine stock solution: mixed 2,5424 g I2 and 24,1525 g KI and made up to 100 ml with water
2/ 150 mg active carbon is mixed with 12,5 ml jodine solution from point 1 /
3/ At equilibrium were performed filtration and titration with 10 ml of the filtrate with a volumetric solution Na2S2O3 ( conc. 0,075 mol/dm3) - consumption 14,5ml of solution Na2S2O3
Questions:
A/the initial concentration of the iodine solution before the test
B/equilibrium iodine concentration found during titration
C/amount of adsorbed iodine on the sample surface - iodine number...in mg/g
D/ an estimate of the specific surface area of the AC sample assuming a monimolecular layer. Each iodine molecule occupies an area of 0.21nm2.
ad A /iodine content in KI...126,9/166...76,4% of I
in 24,1525 g KI is 18,45251 g I
the amount of iodine in the stock solution...18,45251/2+2,5424= 11,77g I2
concentration of the iodine solution...11,77 g I2 in 100g of solution...117,7 g/dm3 I2...?
reaction of tittration: 2 S2O32−(aq) + I2(aq) → S4O62−(aq) + 2 I−(aq)
2 moles of thiosulfate react with 1 mol I2
consumption of thiosulphate...14,5 ml 0,075 mol/dm3 solution...0,0010875 mol of thiosulfate
equilibrium iodine concentration ...0,000544 mol I2 in 10 ml of the filtrate...0,0544 mol/dm3 I2
Chemistry news on Phys.org
This is rather chaotic, but some problems are easy to spot.
You are confusing free iodine capable of reacting with with total iodine present in the form of iodine and iodide (and mostly inert in the context).
so in the solution of I2 in KI I have to count only with the concentration of the original I2?I don't have to count on the amount of KI?
concentration of the iodine solution...2,5424 g I2 in 100g of solution...25,424 g/dm3 I2...?
Yes, iodide is there mostly to improve iodine solubility (google triiodide).
ad B/equilibrium iodine concentration found during titration ?
reaction of titration: 2 S2O32−(aq) + I2(aq) → S4O62−(aq) + 2 I(aq)
2 moles of thiosulfate react with 1 mol I2 consumption of thiosulphate...
ad C/
amount of adsorbed iodine = original amount of iodine - equilibrium amount of iodine during titration
the original amount of iodine added to the activated carbon:
12,5 ml of solution, concentration 25,424 g I2/dm3...0,3178 g I2...0,00125 mol I2
16K
13K
