Is 0.999... Truly Equal to 1?
  • Level: Undergrad
  • Thread starter Thread starter Mentat
    Proofs
229 replies · 38K views · last reply
loseyourname said:
Kind of like the way cellular automata have been used recently to model biological systems?
are you asking me?
in that case, i'd say... erhm... something like it... but cellular automata uses regular math of course... on the other hand, cellular automata is time dependent and deals with uncertainties aswell, am i right? so i guess it could be paralleled...
it's hard to imagine another kind of math, since we're so used to think in the old mathematical patterns, but i think at some point it migth become usefull or even necessary to evolve it, just like classical physics...
Mathematics news on Phys.org
Speaking of quantum mechanics seems to be antithetical; mathematically, QM didn't replace anything, but it did push existing analysis to its limits (haha) and spurred developments in the subject. As far as I know, LQG and ST do the same.
did i say it replaced anything? no... fine then... did i say the new math would replace the old? certainly not...
but it didn't just push existing analysis to its limits. classical physics were 100% unable to explain the phenomenoms that quantum mechanics did... so it did much more than that...
seriously, what is your problem with the idea of a new way of calculating? like i said, it should be coherent, so it wouldn't replace what you seem to hold so dear...
Yes, but I was talking about the mathematics, remember?
I get the impression that you are calling for a change, not for any particular theoretical or practical reason, but because for whatever reason you think "infinities" are "bad".
This sort of affliction is far too common, and is a great contributor to the popular misunderstanding of mathematics and science, so I like to spend a good deal of effort trying to combat it. If I'm seeing it where it does not exist, I apologize.
balkan said:
are you asking me?
Mathematics is not at all like physics. In mathematics we establish the axioms, in physics, we do not even know if there is any or what are the axioms of the system.That's why we can develop ANY theory that is compatible with experiments, observations and the deductions. So even we change the mathematical system we would have to add axioms which won't make it a new kind of math.
I get the impression that you are calling for a change, not for any particular theoretical or practical reason, but because for whatever reason you think "infinities" are "bad". If I'm seeing it where it does not exist, I apologize.
you are... infinities works splendidly... i would hate to do quantum mechanics without it... it is for a practical change however... to fully develop string theory e.g., many physicists believe a new mathematical system is necessary...
this makes no sense... since we don't know if there are axioms at all, we can develop any model and any theory using our mathematical system, which has inevitably got axioms involved?
anyway...
we wouldn't have to "add" axioms... the new system should simply just be backwards compatible with the new system (so that a proper adjustment of the new system would give the same results as working in the old one). But it should be more capable of explaining the physical phenomenons that seems to care **** about being in the dimension visible to humans...
and that's my entire point: there are phenomenons which a are very difficult to model and create theory for using our dimensional dependent math system...
look, I'm not expecting you to understand what i mean. it's obviously not that easy to swallow, but just like new concepts like the integral, infinity and zero have been involved, so can other new concepts... perhaps these concepts will be developed so that our present math system cannot copy it very well, while the new system could be used like the old one...
=1.0000000000...
0.999999999... is not equal to the whole number 1 but to the real number 1.000000000000...
Check the definition of real number; a pair of converging sequences is actually involved.
Actually you don't have to sum the series. The completeness property of the real numbers guarantees there is a real number, which you can prove to be unique, as the least upper bound of the set of numbers { xi : xi = 1.999...999 for i decimal places} . Proving that the number is neither greater nor less than 2 is then easy.
anyway...
Do you know what is an axiom ? I guess you can't swallow well what i said.
Define "new mathematical system ", we are not on the same track.
yes i do know what an axiom is... but your sentence made no sense...
"new mathematical system" like imaginary number theory was... just "bigger"... it can explain phenomenoms that the "old" theory can't, but is still coherent with the old... i wouldn't quite call it a new paradigm or anything, since it would still just be "math"...
they're trying it with string theory, but I'm having my doubts about it... but you got to start somewhere, right?
I was doing some research about .999~ = 1 tonight and I came across this page. I agree completely that .999~ is indeed equal to 1. However, I have question. Based on what I read, I concluded that .999~ can be expressed as an infinite geometric series such as 9/10 + 9/100 + 9/1000... etc. From what I've learned in math class, this should converge to 1, but not equal it. However, the proofs still show that .99~ is 1. I was wondering that since this series "approaches" 1, but still equals it, then can the sum of any infinite geometric series actually equal a sum instead of converging towards one? For example, if we are given a list of numbers in a series and I find that the sum of these numbers converges to say.. 30, then would there be a way I could prove that the sum is EQUAL to 30?
I may be confused about the whole concept of series in general, so please correct me if I'm wrong about anything here.
If a sequence converges to a number, then, when summed over an infinite number of terms, it would equal that number.
This is the meat of the entire debate that usually surrounds the 0.999... = 1 issue. 0.999... only equals one when you tack on an infinite number of nines, which makes some people uneasy. There is nothing mathematically wrong with summing an infinite number of terms, however, no matter how conceptually difficult it is for some people to grasp. The notation 0.999... specifically means an infinite number of nines, and is equal to one.
- Warren
Yes, it's true by definition. The term "sum of an infinite series" means "the value to which the partial sums converge".
So, if the partial sums converge to 30, then the sum is equal to 30.
Well, I guess that answers my question, but I still wonder why my math teacher specifically marks points off for writing "the sum of the series is 30" as opposed to "the sum of the series approaches 30 or converges to 30." :confused:
I am new around here, so I don't know if anybody presented this already, but here goes:
0.999999...=x
10x=9.99999...=9-0.99999...=9-x
9x=9
x=1
And yes, sum of infinite geometrical series is one particular value when b(n+1)/b(n)<1. It's like in Zono's paradox with Achileus and a turtlle...
IMO its just rediculous to try to say that 0.9 repreating = 1. We KNOW that it is infinately close to, but will NEVER actually EQUAL 1. Maybe using mathematics we can say that, but it is not logically true, so there must be flaws in mathematics. You can give all the arguments you want to try and prove it, but its kind of a circular argument. You have to assume that math is flawless, and i don't see why would would assume this when it contradicts itself.
Also, weird things happen with infinity. For example, what is infinity/intinity... what is infinity/infinity squared. How do you enter notation in this forum? :mad:
It will be equal to one when there are an infinite number of nines, which is precisely what the notation 0.9... means.
Mathematics does not have flaws. It begins with a set of axioms, and derives a set of conclusions. You can start with different axioms if you like, and you'll get different conclusions. The axioms normally used in mathematics can be used to prove 0.9... = 1. There is no question about it, nor is there any room for debate.
It does not contradict itself. Once again, all you must do is select your axioms, and the results follow from them.
Indeterminate.
Indeterminate.
Like this:
[tex]\frac{\infty}{\infty}[/tex]
- Warren
1-0.999...=1/infinity
It is infinitly close to 0, but will NEVER reach it. It is like some immortal person writing down zeros forever and ever after the decimal point, with the idea that he is going to write a 1 as his last digit. We know that he will never reach his last digit, but his number will never equal zero, because it isn't complete... even though he gets infinitely close to it.
This is a shaky argument, and I suspect you know it. No real person ever needs to be capable of writing down an infinite number of zeros to make an expression true. The operative word is if. If a person could write down an infinite number of nines, the resulting number would be equal to one. That's what the notation "0.99..." means, regardless of whether or not a human hand can write it out digit for digit.
- Warren
Not an argument at all! 1- 0.999... "is infinitely close to 0 but will never reach it" only means that the poster does not understand what 0.999... (or 1- 0.999...) means. Numbers are fixed, specific things- they are not "reaching" something and don't depend on any person, real or hypothetical, writing down digits. Digits are something we use for convenience- every number has an existence of its own completely independent of "digits". 0.999... IS 1.0 because the notation "0.999..." means "the limit of the sequence 0.9, 0.99, 0.999, etc." Notice that the definition is clear: an infinite decimal is the limit of such a sequence, not the sequence (a string of digits) itself.
It seems like the same principles used here are the ones used to solve zeno's paradox... I posted some of zeno's paradoxes in another part in the math forum... correct me if I am wrong.
Tom,
Yep, that's correct. A proper understanding of the sum of infinite series solves this problem and Zeno's paradoxes the same way. An infinite series can have a finite sum.
- Warren
Well, 0.999... is just a representation.
It means infinite 9's after the decimal point. It's not a growing number - all the 9's are already there! It's not required a high level of abstraction to understand it (or is it?!), and children commonly accept it.
So, anyone who can understand that
1/3 = 0.333... ,
should understand that
3 * 1/3 = 0.999... , too.
And then, they should understand that
1 = 3 * 1/3 = 0.999...
But, incredibly, some people have serious difficulties in understanding these equalities. Personally, I believe if an adult refuses to accept the first equality, then even all the arguments in the world are not enough to go beyond.
I think that in general the people who have trouble with these concepts cannot see infinity as anything but a large finite number. Until they can be convinced that infinity is NOT simply a large finite number there is no argument that they will be able to comprehend.
Okay let me answer this dumb thread for you guys. 0.9 repeating does NOT =1. The problem comes in the base 10 math system. 1/3 is not exactly 0.3 repeating. 1/3 cannot be accurately represented by the base 10 system, base 12 would be much better than base 12 since we could represent 1/3, and 1/4.
I can understand that infinity means that it has forever 9s. It has no limit to the number of 9s after the decimal point. However, what some thick headed idiots don't realize is that 1 is a limit.
You have just called everyone with a reasonable Math degree a thick headed idiot. I take that personally and have issued you a warning for insulting behavior.
Please take a math course beyond high school calculus.
Edit: Meanwhile, study the proof starting on page 2 of the link I posted in Post #5 of this thread. It does not rely on taking any limit, but does rely on the definition equality on the real number line.
Okay 1 = 5, 3 = 7. Whatever you want to think. However, if 0.9 repeating = 1 then they wouldn't have named them differently in the first place. They are 2 numbers that could be represented as 2 lines, one line being just a 'point' longer than the other.
Ah, I see. So [itex]\frac{6}{4}[/itex], [itex]\frac{3}{2}[/itex], [itex]1\frac{1}{2}[/itex], and 1.5 are all different numbers! I can't believe I thought they were all the same. :rolleyes:
How can a number be represented as a line? Oh, I see, you meant line segment. Well, as I'm sure you know, between any two distinct points there is another point. If both have their left endpoint at the origin, what lies between the right endpoint of the line segment representing 0.999... and the line segment representing 1?
Integral said:
Consider this inequality.
[tex]1 - .1^n < x < 1+ .1^n[/tex]
It seems clear that there is only a single number for which this is true for ALL values of n>0, x= 1 . This is a simple statement that any number added to x results in something greater then 1, or any number subtracted from x results in something less then one. I doubt that you will find many people who will argue with the truth of the statement, x=1.
Now, in the link I posted above, I show that using simple arithmetic, involving only valid rational numbers, one can construct this inequality.
[tex]1- .1^n < .999... < 1+.1^n[/tex]
notice that is the exact inequality as above, thus we have x=.999... If the original statement is correct that the inequality can only be satisfied by 1 you must be lead to the conclusion that
1=.999...
I don't get what you are saying here. It seems to me that while 1- .1^n = .999... maybe be true, this doesn't make sense... 1- .1^n < .999... < 1+.1^n. You are saying that 1cm - (and infinitely small amount of space aka a point) is greater than 0.999...cm, which is the same thing as far as i can tell.
Alright, maybe i have a bad example there, if space is quantisized. Anyways, since mathematics is abstract, i don't see why there can't be an infinitely small amount. Wouldnt this be 1/infinity? If you had an infinite amount of 1/infinities you would get 1, but if you have (infinity - 1) amount of 1/infinities you would get 0.9... so there is a difference theoretically.
