Does the Series 1-1+1-1+1... Truly Equal 1/2?
  • Context: High School
  • Thread starter Thread starter cmb
The infinite series S = 1 - 1 + 1 - 1 + ... does not converge to 1/2, as the assumption that it sums to a number S is false. The series oscillates between 0 and 1, and its sequence of partial sums (1, 0, 1, 0, ...) does not converge. The logic used to manipulate the series leads to a vacuous truth, as it relies on the false premise that the series has a limit. Therefore, the conclusion that S = 1/2 is incorrect, and the series does not have a defined sum.
  • Understanding of infinite series and convergence
  • Familiarity with the concept of partial sums
  • Knowledge of limits in calculus
  • Basic principles of proof by contradiction
  • Study the definition of convergence for infinite series
  • Learn about Cesàro summation and its applications
  • Explore the properties of alternating series
  • Investigate the implications of rearranging terms in series
Mathematicians, calculus students, educators, and anyone interested in the foundations of series convergence and mathematical logic.
cmb
TL;DR
Is 1-1+1-1+1... = (1/2) , if not where does this calculation go wrong?
Take
S = 1-1+1-1+1-1...
and therefore
S = 0+1-1+1-1+1...
Line up the first 1 with 0 and sum, 1+0=1 and the rest cancel out.
S = 1-1+1-1+1-1...
S = 0+1-1+1-1+1...
So 2S = 1
S = 1/2
But that's wrong. S can only be 1 or 0?
You've proved, using some properties of limits, that IF that infinite series converges, then it must converge to ##1/2##. What you haven't proved is that series converges in the first place. And, in fact, using the definition of the sum of an infinite series, you can show that it does not converge.
Why does it need to converge for the logic of summing those infinite series?
It doesn't need to converge for the logic to hold. But, it does mean that your logic has led to a vacuous truth.
But, why?
Where is the logic flawed?
The logic is not flawed. Logic is deducing one thing from another. This is the basis of proof by contradiction. You assume what you suspect is a falsehood, apply valid logic and reach something you know to be false. Therefore, the original assumption must be false.
In this case, if you already know that the series does not sum to ##1/2##, then the tacit assumption that the series has a limit leads to that falsehood. It is, therefore, the original assumption that is false - not that the logic must be flawed.
In no way did I assume the series has a limit, but that every member of the series can cancel out.
A 'series with a limit' is a conventional phrase, not a piece of scientific logic based in abstraction.
The logic here is that if you line up two infinite series, off-set them, and cancel each of one member from the other, then logic gives the total sum of the two series together, cancelling each other out off to infinity.
It is a principle used all the time, so either it is OK to do that, or it is not OK to do that at all.
My question is; why is the logic flawed for this series and not for others? I can accept as an assertion that a series must converge for this logic to hold, but my question is why? Making an assertion and dismissing anyone who asks for some logic as to why the assertion is correct, isn't good science.
  • Skeptical
Basically the point is as soon as you write let S=... You have made a mistake. The thing in the right hand side doesn't equal anything, it's a series of symbols that you did random manipulations with.
In theory it's no different than saying something like sin(x)/(n) = six by cancelling the numerator and denominator, other than the mistake being a lot less obvious.
A large part of calculus/analysis is taking infinite sums of numbers, and deciding if they actually end up equaling a number or not. There are a lot of things you need to do carefully, even if a sum does end up equaling a number, if you rearrange the terms of the sum then you can get a totally different number.
Fine that you say that. But my question is still not answered. How can you tell it is wrong here, but not in other examples?
Yes you did. You assumed it summed to some number ##S##.
cmb said:
Take
S = 1-1+1-1+1-1...
That assumption is false. There is no such ##S##.
Sorry I wasted my time.
Formally, a series converges if the sequence of partial sums converges. For this series: (1,0,1,0…) which does not converge.
PeroK said:
Yes you did. You assumed it summed to some number ##S##.That assumption is false. There is no such ##S##.
No. "S =" means S is 'equivalent to something'.
Could be a set or range or something undefined, or something else.
But the logic of cancelling the terms of the infinite sequence then suggest it is a number. If the answer had come out 'undefined' then indeed the maths logic would have been clear it was not a number. But the cancellation of the set of all those values did give a number.
Like if I wrote "S=1/0", I did not pose there at all that S was a number, and in fact the RHS is undefined therefore S is undefined. At no point did I make an assumption about the nature of what S was.
So how come this sequence of cancellations can be dismissed, but others are acceptable?
  • Sad
And that something has to exist, and your S does not. The sum you wrote does not exist.
They are if and only if the series converge. That is one of the basic theorems on series. You can manipulate the summands if the series converge. If it does not, you can't.
and I'm asking what the mathematical explanation for that is?
Right, so I just asked above what that theorem is that proves this is only possible with a converging series. I cannot find anything that explicitly proves this proposition. I'm asking for your help to either link me to it or put it forward here.
Why that series does not converge? Because the limit of ##(-1)^n## does not exist. Necessary condition for ##\sum a_n## to converge is that ##\lim a_n=0##.
Well, I guess others may help with this one, because I learned that theorem like 12 years ago, and I don't remember the proof 🦜
We all know what you are asking and we all agree on the answer - which you have been given several times now. It's your refusal to accept that answer that confounds us.
The operations that you apply to get the limit can only be proven to work if the series is convergent using the above definition.
That being said, what you are doing essentially falls under cesaro summation
https://en.wikipedia.org/wiki/Cesàro_summation
You answered that yourself:
There is nothing that exists in mathematics that is both 1 and 0.
cmb said:
Take
S = 1-1+1-1+1-1...
No. In the equation in the first quote, you are saying that S is a number that is equal to the expression on the right side. The expression on the right side is NOT a set, or range, or something undefined.
@cmb, as @PeroK notes, the question you asked has been answered multiple times, so I'm closing this thread.
