Is 2.5 m maximum length of lintel? Why?
  • Thread starter Thread starter avito009
    Length Maximum
The maximum length of a lintel is often cited as 2.5 meters, primarily due to architectural constraints related to standard door frames and the potential for sagging. However, from an engineering perspective, openings wider than 2.5 meters are feasible using header beams, particularly steel universal beams, which are preferred for larger spans. The discussion highlights the importance of material choice, such as laminated beams, and emphasizes the need to consult local specifications for lintel requirements based on specific applications.
  • Understanding of lintel and header beam concepts
  • Familiarity with architectural constraints in construction
  • Knowledge of material properties, specifically steel and laminated beams
  • Awareness of local building codes and specifications
  • Research the properties and applications of steel universal beams
  • Learn about the design and installation of laminated beams in construction
  • Investigate local building codes regarding lintel specifications
  • Explore architectural design principles related to door frame dimensions
Architects, structural engineers, construction professionals, and anyone involved in building design and material selection.
avito009
I read this in Gordon's book "Structures or why things don't fall down". I read that the maximum length of lintel should be a maximum of 2.5 metres. Why? What if its more?
The way you're quoting it is very ambiguous. What material? What kind of bonding agent (if masonry)? Is it load bearing?
I'm guessing, based off your limited information, is that 2.5m is an architectural constraint due to the relatively tight fit that doorways require. If you start spanning an opening more than 2.5m (8ft), standard wooden trim/door frames, you could have sag issues.
But, from an engineering stand point, there's no reason you can't have an opening wider than 2.5m. That's what we have "header beams" for. I guess it would be nice to know if he's comparing a header beam to a traditional lintel (headpiece on 2 columns).
I don't have the book but the only thing I can think of is that steel universal beams are preferred over concrete lintels for larger spans.
Perhaps you are thinking about standards housing construction, ie wood. I would imagine the standard is 2x8 or 2x10. I don't have my book handy but I would think 2x10 would work for a 2.5 metre opening. Maybe 2x12. But that isn't to say that other materials can't be used. For example, they make super strong laminated beams now that can be used for much more than 2.5m. You need to find out what you need a 2.5m (or greater?) lintel for. And then find the right specs in your area.
  • · Replies 17 ·
