Is 2ab Always Less Than or Equal to a² + b² for All Integers a and b?
  • Context: High School
  • Thread starter Thread starter PhysicsBoyMan
    Proof
The discussion revolves around the inequality \(2ab \leq a^2 + b^2\) for all integers \(a\) and \(b\). Participants explore various methods of proof, including algebraic manipulation and contradiction, while seeking a formal justification for the statement.
  • One participant suggests that proving the inequality requires a formal proof rather than relying on specific examples.
  • Another participant points out that the expression \((a-b)^2\) is relevant, as it leads to the conclusion that squares are non-negative.
  • There is a discussion about rearranging terms and substituting squares to derive the desired inequality.
  • Some participants propose that starting from a true statement and transforming it can lead to the proof of the inequality.
  • One participant mentions the possibility of using proof by contradiction, suggesting that assuming the opposite leads to a contradiction.
  • Another participant expresses appreciation for the insight regarding transforming true statements into the desired form.
Participants generally agree on the validity of using squares and transformations in their reasoning, but there is no consensus on a single method of proof. Some methods are proposed, but the discussion remains open-ended regarding the best approach.
Participants express uncertainty about the clarity of some comments and the implications of their reasoning. The discussion includes various mathematical approaches without resolving which is the most effective proof.
PhysicsBoyMan
a and b are integers
Prove that:
2ab <= a2 + b2
I have tested various values for a and b and determined that the statement seems to be generally true. I'm having a hard time though constructing a formal proof.
It will not do to suppose the statement is wrong and then provide a counterexample. This would only prove that the statement is true for those particular values of a and b, and not for all values.
I learned about mathematical induction but I think that method is used to prove statements about a well-ordered set. a and b can be any integer so I don't think that would work.
I wondered what kind of statement may have simplified to produce a2 + b2 so I played with (a+b) * (a+b) which produced a2 + b2 + 2ab and also with (a-b) * (a-b) which produced a2 + b2 - 2ab. This looks similar to the original statement, and I feel like I may be onto some clues.
Without giving me the answer, I wonder if someone could give me a push in the right direction?
The last formula gives you the answer. What do you know about squares?
Well I know that squares are always positive.
Then gather all together. Start with "all square are positive". Then substitute a certain square of one of your formulas and rearrange the terms..
I don't know what some of your comment means. I'm trying hard to figure it out. I'm looking at the term (a-b)2 and I think that may be the "certain square" you are talking about. It's equal to a2 + b2 - 2ab though so I don't know what I could substitute it for. Maybe I'm on the wrong track here altogether.
No, you are done. The square is not negative (##≥ 0##) and all which remains, is to add ##2ab## on both sides.
How is that a proof that 2ab is always less than or equal to a2 + b2 when a and b are integers?
The only way to help you further is to type in the proof.
Because you can only derive true statements from true statements, it is a proof:
##0 ≤ (a - b)^2## for all integers, and even for real numbers, too, is a true statement. The next step is to multiply the square which is of course also true. Shifting numbers by addition doesn't change the order, so you are allowed to add ##2ab## on both sides and get again a true statement, which is the one you want to have.
Thanks. I didn't think about it like that. That is, starting with a separate true statement and transforming it into the one I want.
That's probably the simplest proof but you could have done it simply by contradiction as well:
Suppose ## a^2 + b^2 < 2ab ## then
##a^2+b^2 -2ab <0##
And
##(a-b)^2 <0##
Which is a contradiction.
d
##a^2+b^2 -2ab <0##
And
##(a-b)^2 <0##
Nice one Perok. Contradictions are a lot more intuitive often times.
  • · Replies 66 ·
  • · Replies 40 ·
9K
