Is a diffeomorphism if the inverse function
A function f is a diffeomorphism if it has an inverse f^{-1} that is differentiable, and it is a local diffeomorphism at a point p if there exists a neighborhood around p where f is both one-to-one and onto. To determine if f is invertible, one must check if it is one-to-one and onto, which does not require topological considerations. The local diffeomorphism can be assessed by calculating the differential of f and checking if it is an invertible linear transformation at specific points. An example involving spherical coordinates is provided to illustrate these concepts, focusing on demonstrating differentiability and calculating the Jacobian matrix. Understanding these definitions and methods is crucial for solving exercises related to diffeomorphisms.
atomqwerty
I've read that a function f given by f:U\rightarrow V is a diffeomorphism if the inverse function f^{-1} exists and is differentiable. I've also read that that function is a local diffeomorphism in a given point p\inU if it can be found a range A around p such that the function f verifies f:A -> f(A)
I'm really in troubles with all those definitions. I've to do an exercise in which I've been asked to say if a given function is a diffeomorphism, and my question is: how do I know if a function has the inverse f^{-1}?
thanks a lot!
I'm a bit confused. Are you just asking how to determine if f(x) is invertible? You just need to check that it is both 1-1 and onto. There's nothing topological about that part. Or are you wondering how you prove that the inverse function is differentiable?
It might help if you post some specific functions that you're looking at
The question is mainly how to determine where (in which points) a function f is a local diffeomorphism, that I think leads us to determine when the funtion is a diffeomorfism near of that point p.
Thank you!
The general strategy is to calculate the differential and determine if it's an invertible linear transformation. The points at which it is are where f is locally a diffeomorphism. If you have a specific example you want to look at we can do that
Sure, I quote you an example of spherical coordinates,
Let be the function
f:R+ x R x R -> R3
{r,phi,theta} -> {rcos(phi)sin(theta),rsin(phi)sin(theta),rcos(theta)}
Demonstrate that f is differentiable. Calculate de Jacobian matrix and determine in which points is a local diffeomorphism. Calculate the range of R+ x R x R in which the function is a global diffeomorphism.
PS. Sorry about not using LaTeX, I had too much troubles with it.
Thank you
  • · Replies 25 ·
