Worldline Curve vs Trajectory: What’s the Difference?
  • Context: Undergrad
  • Thread starter Thread starter SaintRodriguez
    Curve Trajectory
The discussion centers on the distinction between a worldline, a curve, and a trajectory within the context of physics, particularly in relation to general relativity and mathematical representations. Participants explore definitions and implications of these terms, examining their usage in both mathematical and physical contexts.
  • Some participants propose that a worldline can be considered both a curve and a trajectory, while others seek to clarify the distinction between these terms.
  • A participant suggests that a curve is a mathematical object, while a trajectory represents the set of images that the curve maps, prompting questions about the meaning of "set of images."
  • Another participant references a specific text, "Semi-Riemannian Geometry With Applications to Relativity," to illustrate how definitions may vary, noting that some references define a particle as a mapping and its image as the worldline.
  • One participant defines a curve in the context of general relativity as a smooth map from real numbers to a differentiable manifold, while reserving the term "trajectory" for solutions to equations of motion.
  • There is a discussion about whether worldlines should only refer to force-free trajectories, with some participants arguing that worldlines can also describe motion influenced by interactions.
  • A participant expresses a preference for the term "curve" over "trajectory," associating the latter with non-relativistic interpretations of particle paths.
Participants do not reach a consensus on the definitions and distinctions between worldlines, curves, and trajectories. Multiple competing views remain, with varying interpretations based on context and reference materials.
Definitions of "curve" and "trajectory" appear to depend on the mathematical and physical context, and there are unresolved nuances regarding the implications of these terms in different references.
SaintRodriguez
Is a worldline a curve or a trajectory? Why?
What is the difference?
I would say “curve”, but if someone else said “trajectory” I wouldn’t correct them. I don’t know the difference in this context
I would have said both. What's the distinction you're trying to make?
A curve is the math object like a function and the trajectory is the set of images that the function (curve) mapped.
the set of images
What is this “set of images”? Are you just talking about the mathematical representation vs the physical thing that the math represents?
@SaintRodriguez you might want to give some actual references that give the definitions of "curve" and "trajectory" that you are using.
I think that this can vary, i.e., depends on the reference being used. A reference that takes great care with the mathematics, "Semi-Riemannian Geometry With Applications to Relativity" by Barrett O'Neill, defines a particle to be a (particular type of) mapping (function), and the image of mapping to be the worldline of the particle. Other references might define the mapping itself to be the worldline, and references that take less care mathematically might blur the distinction between a mapping and the image of the mapping.
From O'Neill's book: "Definition. A material particle in ##M## is a timelike future pointing curve ##\alpha : I \rightarrow M ## such that ##\left| \alpha'\left(\tau\right) \right| = 1## for all ##\tau## in ##I##. The parameter ##\tau## is called the proper time of the particle. ... its image ##\alpha\left(I\right)## is a one-dimensional submanifold of ##M## called the worldline of ##\alpha##."
Here, ##M## is the spacetime manifold, and ##I## is an interval of the real line.
That's a good question, because the terminology is a bit unclear in the physics literature. For me a curve is any smooth map between the real numbers (or an interval, if you have a finite curve) to a differentiable manifold, and spacetime is described in GR as such a differentiable manifold (with the extra properties making it a pseudo-Riemannian manifold, i.e., with a pseudometric and the uniquely defined torsion-free affine connection, compatible with this pseudometric). Another name for such a curve in relativity is "worldline".
The word "trajectory" I reserve for the solution of the equations of motion for a point particle (or the pseudo-photon interpretation of the eikonal approximation of electrodynamics in GR), which are timelike (lightlike) worldlines. If there are no forces, i.e., only gravity/aka spacetime curvature, then these are spacelike or timelike worldlines.
Why would worldline refer only to force free trajectories?
Maybe that was formulated somewhat misleading. Of course also worldlines describing motion under the influence of interactions, e.g., the electromagnetic interaction, I would call trajectories.
To me the word trajectory has the meaning of the path of a particle in space over some time. And is very non-relativistic. I would say stay with curves not to be misunderstood.
  • · Replies 18 ·
  • · Replies 42 ·
  • · Replies 17 ·
  • · Replies 41 ·
  • · Replies 25 ·
