Is Angular Momentum Conserved During the Changing of the String Length?
Angular momentum is conserved when the length of the string is shortened, as the mass moves in a circular path. The initial angular momentum can be expressed as L = m * v * R, and when the string length is halved, the new angular momentum must equal the initial angular momentum. The speed of the object remains constant despite the change in string length, which implies that the angular velocity will increase to maintain conservation of angular momentum. The new period can be calculated using the adjusted radius, but the initial calculations leading to 0.5 seconds are incorrect due to misunderstanding the relationship between angular velocity and period. Understanding these principles is crucial for solving problems related to rotating systems.
AlexanderIV
An object with mass m is attached to a string with initial length R, and moves on a frictionless table in a circular orbit with center C as shown in the figure. The string is also attached to the center, but its length is adjustable during the motion. The object initially moves with velocity v and angular velocity ω.
Given: m = 500 g, v = π m/s, R = 50 cm
If the length of the string is shortened from R to r = R/2 while the mass is moving, what will be the new period in SI units?
T = (2πR) / v
T = (2πR) / v = (2π0.5) / π = 1
=> T = (2πR/2) / v = 0.5 s
But apparently 0.5 is not the correct answer and I do not understand why.
Does the speed change when the string is shortened?
No, it doesn't.
AlexanderIV said:
No, it doesn't.
Can you think of any physical quantity that remains conserved during the changing of the length of the string? (Maybe it's something you have recently covered in your course.)
