Is Angular Momentum Conserved in Circular Motion?
The discussion revolves around the conservation of angular momentum in a scenario involving a mass bob attached to a string, rotating in a horizontal circle. The participants explore the implications of forces acting on the system, particularly tension and gravity, and how these forces affect angular momentum about the point of suspension.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants discuss whether angular momentum is conserved, considering the effects of tension and gravity. Questions arise about the role of gravity in exerting torque and its implications for angular momentum conservation.
There is an ongoing exploration of the conditions under which angular momentum may or may not be conserved. Some participants suggest that gravity exerts a torque, which could affect conservation, while others are questioning the assumptions regarding the setup and forces involved.
Participants note that the problem does not specify whether the bob is rotating in air or on a surface, leading to discussions about the relevance of gravity in the analysis. There is also mention of the need for clarity regarding the reference point when discussing moments and torques.
vijayramakrishnan
A bob of mass m attached to an inextensible string of length l is suspended from a vertical support. The bob rotates in a horizontal circle with an angular speed ω rad/s about the vertical. About the point of suspension :
(1) angular momentum changes in direction but not in magnitude.
(2) angular momentum changes both in direction and magnitude.
(3) angular momentum is conserved.
(4) angular momentum changes in magnitude but not in direction[/B]
torque = rXf
angular momentum = rXp
[/B]
i know that answer is a and how it came but i feel it is answer c,because there is only one force tension, and the torque produced by it is zero about point of suspension as r is parallel to f,so shouldn't momentum be conserved?
Is it rotating in the air? Or is it kept on a surface, like, say, a table?
If it's the former, how can you neglect gravity? Please provide some more information.
sir nothing is given about it,and it does not matter
torque = rXf
[/B]
sir, i think gravity acts on the system because it is given vertical support.i edited it sir.
Ok, so does gravity exert a torque?
sir it is not given,but i think it does ,else in a gravity free space how can something rotate in when the string is suspended from a vertical support
It doesn't need to be given. Gravity exerts a force. A force has a magnitude, a direction and a line of action. If you pick some point not in that line of action, the force has a torque about that point.
In the present case, the mass is not directly below the point of suspension, therefore the force of gravity on the mass has a torque about the point of suspension.
thank you very much sir for replying,so tension doesn't exert a torque but gravity does,so momentum is not conserved am i right sir?
In respect of the point of suspension, yes. (You should always make the reference point/axis clear when discussing moments etc.)
What is the angle between:
- the angular momentum vector through the point of suspension, at some instant, and
- the torque due to gravity about the point of suspension?
i think it is 90 degree.
Right. Do you see how that leads to one of the options?
i think here work done by gravity is zero since gravity is perpendicular to velocity,so kinetic energy of the particle is constant so magnitude of angular momentum is constant but direction changes because there is a torque by gravity,am i right sir?
Yes, that's all correct. But what I was thinking of is that torque produces change of angular momentum, ##\vec \tau=\dot{\vec L}##. If the torque is perpendicular to the angular momentum then the dot product is zero, so ##\vec L.\dot{\vec L}=0##. Integrating, ##|\vec L|^2=c##, for some constant c.
thank you very much sir for replying but can we integrate like that because i have not been taught integrating dot product of vectors,we write it as abcoθ and integrate each term.
  • · Replies 17 ·
  • · Replies 71 ·
  • · Replies 30 ·
