Is anything in the physical world infinite?
  • Level: Undergrad
  • Thread starter Thread starter LightningInAJar
    Infinite Physical
79 replies · 12K views
LightningInAJar
TL;DR
Is anything in the physical universe unlimited or just in math?
Is anything in the physical universe unlimited or infinite or does Infinity only exist to make some math work? Is Infinity a real thing outside of math?
The distance you can travel on the surface of a sphere, Moebius band, ...
Likes   Reactions: ergospherical, sophiecentaur, Vanadium 50 and 1 other person
It is still unknown whether the size of the universe is finite or infinite. It could be infinite.
It depends on what you mean by 'anything in the physical universe'. The number of partitions something continuous can be divided into, such the space between two points or part of the electromagnetic spectrum, is infinite. As is how far you can travel on something like a sphere, as Godot said above. But if you're talking about something like the number of particles then the answer is that we don't know. If the universe is infinite in size then the number of particles is likely infinite as well, but we don't know how big the universe is.
I think if the universe is infinite in size then the number of particles must be infinite (I'm assuming isotropic and homogeneous, on large scales, over the whole of it)
That's an excellent question. You already have some excellent answers.
Summary:: Is anything in the physical universe unlimited or just in math?
Well, if you go with “anything” then that would also include infinitesimals since the inverse of an infinitesimal is infinite. And our best descriptions of nature involve infinitesimals, so there is a lot of evidence supporting them and not anything strongly opposing them. So I would keep an open mind on the topic
I remember, when I was a lad, this (the surface of a sphere plus others) was brought up as an 'infinity' example. However, it's finite but 'boundless'.
That's just a mathematical idea and doesn't prove anything ' physical' about the Universe.
Interestingly, the heroic and nerdy Mathematicians sorted out a lot about what infinity can mean, hundreds of years ago. But that's all based on Axioms and some of the results don't necessarily 'make sense' to our intuition.
That may or may not follow, depending on how you define a particle. When really big numbers of 'particles' are involved, the formula for the sum may or may not be convergent. i.e. is 'the number of particles' really an integer?
The surface per se is boundless, but finite - it has a finite area, that can be determined. The distance you can travel, however, is infinite.
Easy way to look at it would be e.g.:
You can "count" the area by painting it with exactly one layer of paint. You start somewhere... ...and eventually you run out of unpainted places. => Finite.
The number of steps you can take in any direction - that is infinite: After each step, you add one to the count, yet you still can take another, uncounted step... ...ad infinitum. Each step is a new one - even though you've been there before...
/nitpicking
[Edited for better understanding]
If the universe or any particular thing were infinite, how could we distinguish that from finite-but-larger-than-we-can-measure?
If position or time or any other quantity were infinitely divisible, how could we distinguish that from discrete-but-smaller-than-we-can-slice?
If it turns out that these things are truly finite or discrete, we might eventually figure that out. If they are truly infinite or infinitesimal, we may never know.
This is basically the intuition behind the mathematical notion of compactness: it's a more precise answer to the question of whether a sphere's surface is finite or infinite.
I can't make sense of that. If the universe is infinite, and homogenous and isotropic, then it is filled with stars and galaxies everywhere. One way to define the number of particles is the number of atoms. No formula is involved. No sums.
There are two ways to express the idea of an infinite number of particles:
Given any number ##N##, you can find at least ##N## particles in the universe.
The set of all particles in the universe is infinite - in the sense that it has a countably infinite cardinality.
That said, you can prove or disprove these properties for abstract mathematical objects but you can't prove them for physical objects in the same way. You can have a model that predicts an infinite number of particles, but it's not clear how you could ever confirm that the model is correct in that respect.
Yes indeed. AFAIK, our speculations that the universe is or is not finite can never be confirmed. But the cosmological principle is not a product of mathematics, it stems from observations; correct?
Like all of science. Our observations so far are consistent with the hypothesis.
Yes, the cosmological principle is a physical assumption underlying the current model. Observations show no clear evidence of finiteness and make the infinite model appealing. But, I'm not sure how infiniteness could ever be confirmed.
PS we could confirm that the universe is finite, in the same way that we have confirmed that the Earth is finite, and not infinite and flat. It's confirming infiniteness that's problematic.
I received the walking around the Earth's equator example in a philosophy forum as well, but you of course pass the same molecules each pass and receive no additional information if not for the passage of time rearranging things slightly. As far as infinitesimal stuff I don't quite understand it. Can you really not cease from dividing the electromagnetic spectrum into smaller slices or space into smaller lengths? Or can we simply not prove otherwise because we are so much larger and measuring things larger than us affords us better tools?
According to our best models, the ones with the most experimental verification, there is no limit. These models underly all of physics, from Newtonian physics to quantum field theory and general relativity.
It is more than that. As far as I am aware there isn’t a known model of physics that both entirely avoids calculus and is consistent with current data.
The OP has equated unlimited with infinite. That's tricky.
There seems to be limits to pretty much everything in the universe, preventing infinites. Here's what I mean:
I would not call such examples infinite or even unlimited.
The OP is asking about the physical world.
You can not actually travel an infinite distance on a sphere in reality. There are real barriers that will ultimately prevent it.
While it can be said to be theoretically infinite (which - by definition - means ignoring certain physical, real-world constraints), that doesn't meet the OP's explicit condition of infinite, IMO. I guess "can't occur in the finite lifespan of the universe" is a boundary.
Likewise - while there are an infinite number of "real numbers" - this can only occur in the abstract world of math. The physical world (as far we we understand) has real constraints on infinite subdivision. I guess "the Planck length" is a boundary.
Dale said:
According to our best models [of EMR], the ones with the most experimental verification, there is no limit. These models underly all of physics, from Newtonian physics to quantum field theory and general relativity.
That is a theoretical limit.
A physically infinite EM emission would have an infinitely long wavelength. Not only would it never oscillate; it would never even start its first oscillation. I guess "an EM wave that is too long to oscillate" is a boundary.
An infinitely short wavelength would have other problems. I think, including - but not limited to - having being an infinite amount of energy. I guess "would have more energy than the universe" is a boundary.
DaveC426913 said:
A physically infinite EM emission would have an infinitely long wavelength. [...]
While your arguments about the zero and infinite wavelengths hold some water, ...
...it completely ignores what, for simplicity's sake, I'd call the "inner" infinity: You can find an infinity of wavelengths between any two arbitrarily chosen wavelengths. Black body radiation and doppler shift take care of that...
To learn more, try looking at the Bolzano-Weierstrass-Theorem e.g. @wikipedia or try googling Bolzano Weierstrass Epsilontics (or epsilon-delta) ...
While it's way easier to use math to prove it, it still is observable in the physical world - down to the best precision your measuring instrument permits. And when you then build a more finely graded instrument, you can open the next can... ...ad infinitum.
Depends on the sphere. Where's the insurmountable barrier on a billard ball?
The only barrier there would be the lifespan of the traveler... ..and, meh, he'll just pass the baton to the next traveler...
Also, if an insurmountable barrier exists, it's actually, by definition, not a sphere...
DaveC426913 said:
[...] that doesn't meet the OP's explicit condition of infinite [...]
He didn't give any other than that they have to be there in the real, physical world. All else is your implication only. And that they're easier to prove or explain with math doesn't make them any less real. If you take the time and a sufficiently finely graded (or infinitely long) measuring tool, they can be observed.
DaveC426913 said:
[...]IMO. I guess "can't occur in the finite lifespan of the universe" is a boundary.
Current paradigm has it that the universe keeps expanding, and hence should be infinite in the time-forward-dimension. Yes, there has been some beginning - but there won't be an end. Like with natural numbers: There's a lower limit - 1 or 0, depending on whether it's N or N0 we're talking about, but no upper limit, so it still is infinite.
Slanting the measuring scale yields another set of subdivisions, thanks to trigonometry. And don't tell me that that only exists in math...
Also, there definitely are infinite angles. You can always nudge your observing tool a bit to the right or left...
To give a physical example:
All those faraway galaxies in the recently published JWST image... ...their apparent width is in the milliarcsecond range. But they're composed of individual stars, some of which will be observed when they go supernova, eventually... ...which opens up the micro- and nano-arcsecond scale. Also, they're composed of atoms. Those atoms' apparent width would then be in the ... I won't bother to look up the appropriate prefix right now. You get the image, I suppose.
Are those atoms not real and physical, just because the distance is too great to observe them?
As I said above: Using math as a convenient tool to explain / extra- / interpolate stuff doesn't mean that that stuff isn't real or not physical.
You don't need to invoke anything more than the uncountably infinite set of points in a portion of space. But, that (like the EM spectrum) is a mathematical model of the physical universe. Clearly, we have mathematical models that assume space, time and the EM spectrum are infinitely divisible. But, you can never confirm that fully and conclude that there are, for example, an infinite number of possible wavelengths.
That's explicitly mathematics.
In mathematics the "ad infinitum" is possible by definition. In physics, you would need to confirm by experiment. And an infinite sequence of experiments is physically impossible.
Note that you can plan an infinite sequence of experiments, but you'll never finish them all. You will only ever have conducted a finite sequence of experiments, regardless of how much time you have.
Note also that even if the universe will exist for infinite time, physically that means that time never ends. But, not that at some point you have experienced an infinite amount of time.
I'm not surprised as I didn't get my words together correctly. I've re-thought what I was trying to say and the following may not be so dodgy. The thread is discussing matters like 'how many particles' but at the extremes of conditions our familiar particles are not the same. Theory suggests that particles are created in very low densities and that, under conditions of very high density, the lose their identity so counting them becomes meaningless and any model runs out.
Yes - the established maths doesn't deal with all situations so we can't rely on it to deal with the Infinity question or even give any meaning to it.
This could be interpreted as a personal theory so I will stop now.
Physically, it is limited by the Plank length.
There will be a physical end to any sphere and any person or device attempting to traverse it. They will decompose.
Just because there is no upper limit in theory does not mean that an upper limit can be reached physically.
Take the example of the unlimited frequency of an EMR emanation. At some point, it has more energy than the universe itself. And that's self-contradictory, since it's part of the universe.
It exists physically down to some physical limit. It is at least limited by the Plank length.
No. Your observing tool is physical, and - whether atomic or photonic - has some lower limit of resolution.
Even a science fiction tool of fabulous precision will still be limited by the Planck length.
Really really small is not the same as infinitely small.The OP's question was not 'Are there physical things in the universe that are really, really big or really, really small?' If it had been, this thread would have ended after post 2: "Yes. Lots." :wink:
A physically infinite EM emission would have an infinitely long wavelength. Not only would it never oscillate; it would never even start it first oscillate. I guess "an EM wave that is too long to oscillate" is a boundary.
You shouldn’t have added the [of EMR] to my quote. I was responding with a very general statement about all of modern physics, not limiting my comments to EM at all. That is why I said “These models underly all of physics”.
To clarify, I was talking about calculus. All of our scientific models are based on calculus, and all of calculus is based on infinitesimals. So all of our physical models presume that infinitesimals are physically meaningful. To my knowledge we don’t have any valid physical models that lack this feature.
@LightningInAJar made a very broad original claim, and then brought in the EMR spectrum, but I was still responding to the broader context.
Calculus doesn't depend on infinitesimals, which technically are part of "non-standard" analysis. Standard calculus is based on limits, which require only the properties of real numbers. One such property is the Archimedean property (which is not compatible with infinitesimals):
https://en.wikipedia.org/wiki/Infinitesimal
https://en.wikipedia.org/wiki/Archimedean_property
