Is Biomass Really Carbon Neutral?
  • Thread starter Thread starter russ_watters
    Carbon Neutral
The discussion revolves around the carbon neutrality of biomass as an energy source, particularly in the context of its use in Germany and the EU's classification of biomass. Participants explore the implications of biomass burning on carbon emissions, sequestration, and the environmental impact compared to other energy sources like solar power.
  • Some participants argue that biomass is carbon-neutral when viewed as an energy source, but question this assumption based on the context of carbon sequestration and the source of the biomass.
  • Others suggest that the carbon neutrality of biomass depends on whether existing forests are being used or if new biomass sources are being cultivated, raising concerns about deforestation and carbon release.
  • A participant expresses skepticism about the carbon neutrality claim, suggesting that it relies on flawed assumptions and that the benefits of biomass may not outweigh the environmental costs.
  • There is a discussion about the importance of the baseline used for evaluating carbon emissions, with some participants emphasizing the need for clear accounting of forest regrowth.
  • Some participants propose that using fast-growing biomass sources could be more sustainable, while others question the feasibility of relying solely on agricultural and timber waste for biomass energy.
  • One participant highlights the complexity of framing the question, noting that the discussion often oversimplifies the trade-offs between different energy sources.
Participants do not reach a consensus on the carbon neutrality of biomass. There are multiple competing views regarding its environmental impact, the assumptions underlying its classification as carbon neutral, and the implications of using existing versus new biomass sources.
The discussion reveals limitations in the assumptions about biomass sustainability, the need for extensive modeling to support claims of carbon neutrality, and the potential for differing interpretations based on the definitions of carbon neutrality and environmental impact.
Readers interested in renewable energy sources, environmental policy, carbon emissions, and the sustainability of biomass as an energy option may find this discussion relevant.
  • #61
fresh_42 said:
You cannot simply say it is not true or exaggerated.
It is true, but it could be exaggerated.
It would be nice to put it in perspective by comparing it to a volcanic eruption. It would be similarly useful to see the CO2 spike on a plot of C02 trends over several years so that we see how it compares with the background noise.
I don't have that data. Perhaps another PF member does.
  • #62
The point is, that it would have been avoidable. We cannot influence methane emissions in Siberia, but we can influence what we burn down deliberately. Of course, a major volcanic eruption is probably worse, but this isn't the point.
  • #63
There's usually a several month delay between when CO2 is produced/released and when the detectable rise occurs at the sampling stations. It takes time for it to mix and disperse in the atmosphere. But if it is a significant blip, it will be discernable at Mauna Loa and most of the other sampling stations. The time to show up depends on the sampling location and seasonal movements of air masses.
Here's the main link I use and I point students to for what I consider to be reliable CO2 sampling data:
https://www.esrl.noaa.gov/gmd/ccgg/data-products.html
Here's a student paper I mentored making use of that data:
https://arxiv.org/ftp/arxiv/papers/1812/1812.10402.pdf
  • #64
People need to feed their families, even in Brazil. The root cause is too many people on the planet, not the behavior of people.
There are more than 200 million people in Brazil. It could probably support only 20 million without impact on the forests. How would you feed them?
https://www.wolframalpha.com/input/?i=population+trend+brazil
  • #65
Thanks for the links. But how can I use them to compare the "normal" CO2 oscillations with the "spike" caused by the current event in Brazil?
In 2018, there were many wildfires in North America. Can we see the CO2 spikes from those in the global data?
  • #66
Certainly not with palm oil and soy. This is food for our food industry and cheap cattle, not people.
  • #67
As I mentioned, a current event takes some time to reach the detectors. Subtracting the oscillatory background that is normal every year requires some thought. I'd recommend using Fourier Analysis to identify the oscillatory part - there are a number of frequency components with amplitudes that are fairly uniform. Identifying and subtracting the "seasonal oscillations" should be straightforward with care.
But seeing a "spike" from ordinary wildfires is almost as silly as detecting every cow fart. Do the math. How many ppm does an event need to raise the CO2 concentration to be detectable? How many millions of tons of wood need to be burned to cause that rise? How many acres of forest does that correspond to?
A truly globally significant event should be detectable. Cow farts and ordinary summer wildfires - not so much.
  • #68
I have just seen a tv interview (ACN digital) from Richard Westbrook, deputy assistant administrator EPA.
If I would have linked the interview without saying who this man was, I would have earned a **-storm. However, the current EPA is not famous for being neutral. But this man said it out loud: No chance! :biggrin:
  • #69
Would you be so kind as to link it? Normally by google fu is sufficient, but I'm coming up empty.
  • #70
It was a facebook feed and far from being anywhere near a scientific base. I searched for Richard Westbrook on the EPA page, but couldn't find him. This can of course have the trivial reason that he is a deputy assistant administrator in any local office, and the broadcasters haven't been very accurate. Even the timestamp was questionable: only that it came up today doesn't mean it was up to date. And it is from a very biased site. I just mentioned it, since it pleased my sarcasm.
So on your own risk. and please don't blame me for this "unacceptable reference".
  • #71
fresh_42 said:
Downplay as "liberal opinions" or alike doesn't make it go away.
I do not now what legit news outlets elsewhere, like the weather channel here in Aus, are saying, but the story I hear is of course you are correct - it is caused by deforestation - possibly even farmers clearing more land. But evidently it was a problem last year, the year before etc etc. Deforestation of the Amazon, and the paltry money spent trying to stop it without success, is a big problem - but it has been a big problem for years. Even conservative talk shows admit that - they just do not think its worse than any other year and make a big deal of why this year is not any different. Its obviously politically charged - some say it provides 6% of our oxygen, others 20% - when I see discrepancies like that I just shake my head. Either way when its gone - and eventually it will - things will not be good,
Thanks
Bill
  • #72
In my opinion there is a far bigger problem than carbon dioxide: the loss of biodiversity, uncounted unknown plants and with them potential drugs. Not to mention the moral crime this represents for the indigenous populations.
  • #73
BillTre said:
I can not recall having ever heard anyone say this.
Sounds like straw-man argument to me.
Its all over the internet and talk shows etc eg:
https://www.sustainability-times.co...w-cheaper-than-coal-but-new-challanges-await/
Renewable enthusiasts make a big deal of it, and as time goes by it will get cheaper still.
What they ignore, and the anti-renewable people are now using it in their arguments, is renewables have different characteristics than coal or nuclear that make balancing a lot harder and more expensive so overall it's not cheaper - yet. To me its obvious we will not have a totally renewable energy supply for quite a while - it will be a mixture. Even the South Australia link I gave, while claiming 100% renewables, admits they need gas generators to kick in every now and then, and to sometimes import power from other states in Australia. And then of course there is the possibility of Fusion power that could change everything.
Thanks
Bill
  • #74
carbon neutral solution doesn't exist == if we take extra energy somewhere (even from our Sun), it always provides extra heating or cooling for Ambient. those changes of temp always affects mass rate of carbon around. The very solution to prevent collapse of Biosphere is, to reduce energy consumption down to reasonable values.
  • #75
I guess this isn't even wrong. The question is: what do you take into account? Coal and nuclear energy is pretty expensive if you calculate long term total costs. However, there will be still the problem to evaluate a human life.
  • #76
Where is another Pauli when we need him (I am certain Fresh knows this but not even wrong was a favorite saying of his, especially to other top tier scientists like Landau - but than again by all reports Landau's personality didn't click too well with Pauli). He could cut through BS like a hot knife though butter. Who is right and who is wrong - its just so politically charged its hard to get the facts.
What I do know for sure is they finally did a survey I have been suggesting for a long time. They went to some less affluent and more working class suburbs and asked how much would you pay extra for your electricity to fight climate change. The answer was zero. They then went to affluent suburbs and asked the same question - the answer was 25%. Yet over the last 10 years electricity prices here in Aus have gone up 117%. Are people willing to pay the price - I suspect no. Remember though most people here live in democracies - if you believe in the democratic process you must expect people to vote for their own interests - its just human nature, What can be done? I think we just have to accept some damage to this poor Earth of ours. Already engineers are working on how to minimize it and when the consequences are catastrophic enough it will be tackled. This is the view of Professor Lomborg and Freeman Dyson. although Dyson believes its doing some good by making the planet greener.
Where I live in Brisbane we are having extinction event marches a court just ruled, correctly, are perfectly legal. I will let our justice system sort that out when they infringe on other rights such as the freedom to go unmolested about your lawful business, but I have zero idea where they are getting the idea we are approaching an extinction event - even an IPCC author wrote an article condemning it. The link I will dig up later.
As promised here is the link by Myles Allen, Leader of ECI Climate Research Program, Oxford
https://theconversation.com/why-pro...12-years-to-climate-breakdown-rhetoric-115489
Thanks
Bill
  • #77
I only have a problem with subsidies. The damages of accidents, severe or just incidental emissions, air and water pollution, waste storage etc. are not fully covered by the price. In this sense, the prices are not really comparable. This is also true for solar energy and wind energy where we do not have sound long term data for maintenance and substitutions. I guess this would be an economic thesis to figure out the total cost balance sheet on a macroeconomic if not global level.
  • · Replies 18 ·
  • · Replies 59 ·
12K
10K
28K
  • · Replies 133 ·
28K
