- 7,523
- 3,048
The longitudinal Doppler effect is the usual Doppler Effect.nakurusil said:Arbitrary angle, please. No Lorentz transforms, please.robphy said:My post directly answers the question with: Yes, the k-calculus... although the transverse Doppler effect will take a little more work.
The transverse Doppler effect is essentially Time Dilation.
For a complete k-calculus proof covering both cases, it's on my to-do list.
Since I've never seen it actually written out, I might write it up into a paper first.
I'm not sure why the 1+1 (Longitudinal) case [which is easily handled by the k-calculus without invoking a Lorentz Transformation] is insufficient for you.
Although the 2+1 and 3+1 cases are important, the longitudinal case is more fundamental. The 2+1 and 3+1 cases are obtained by extension [which would be easier with a Lorentz Transformation.. but could be accomplished without it with more work]. I can write down a pure 4-vector calculation to handle both the transverse and longitudinal cases without ever explicitly using the Lorentz Transformations. So, I'm not sure what you are after.
(It might be worth noting that A.A. Robb practically reconstructed [with much effort] all of the structure of Minkowski space [including obtaining the Lorentz Transformation] starting from a primitive order relation [the causal relation: "after"]. I mentioned this in this earlier thread https://www.physicsforums.com/showthread.php?t=149780 which you may recall.)On another note, isn't this line of discussion actually tangent (or diverging away from) to the OP's original question?
