ohwilleke
- 1,659
Why would you think that MOND fails at local scales?
It doesn’t predict gravitational time dilation or the correct light deflection or the precession of Mercury or the Shapiro effect or frame dragging.ohwilleke said:Why would you think that MOND fails at local scales?
Hi BillKet:BillKet said:Do we need to give up on DM completely and find a new explanation for the observed gravitational behavior of the galaxies (MOND?)?
Dale said:MOND is not a viable alternative, regardless of any perceived problems with DM.
I wouldn’t rush to get rid of DM. It has been observed gravitationally and looks like it doesn’t interact much otherwise. So it will be inherently difficult to detect.
Science isn’t room service where you can order a result to your liking to be delivered by the end of the sitcom you are watching. It is a difficult enterprise and honest science always has a real risk of null results.
The comparison is fair, but I think your timescale is way too short. It took over 100 years to detect gravitational waves, and we knew more about them than we do about dark matter. Science just isn’t a pizza delivery service with a “30 minutes or it’s free” guarantee.Alain_BXL said:but with each day that passes without experimental confirmation of DM, the latter looks increasingly like the modern-day equivalent of the planet Vulcan that was once thought to explain Mercury's perihelion precession.
Hi Alain:Alain_BXL said:the latter seems more like an an hoc hypothesis to fix some observational anomalies
This could not be further from the truth. We have not yet started to scrape off the parameter space of most DM models.Alain_BXL said:Also, it seems that DM is gradually running out of places to hide, no?
Agreed. My intended point there wasn’t that they are the same kind of search, but that gravitational phenomena can be very difficult to detect. As far as kinds of searches I think the neutrinos are more analogous.Alain_BXL said:However, I'm not sure that I accept the equivalence between gravitational waves and DM. The former were predictions of a broader theory, the latter seems more like an an hoc hypothesis to fix some observational anomalies
Definitely not. If they interact only gravitationally then we are not merely years away, but probably centuries away from being able to detect them. And there could be new interactions anywhere between the weak force scale and the gravitational scale. The room to hide is enormous. I don’t think you appreciate how weak gravity is and how far away our instruments are from detecting individual particles gravitationally.Alain_BXL said:Also, it seems that DM is gradually running out of places to hide, no?
Buzz Bloom said:Hi Alain:
If I remember correctly, the earliest thinking about what we now call dark matter was a result of analyzing what happened during the early period of the universe
Regards,
Buzz
Dale said:Definitely not. If they interact only gravitationally then we are not merely years away, but probably centuries away from being able to detect them. And there could be new interactions anywhere between the weak force scale and the gravitational scale. The room to hide is enormous. I don’t think you appreciate how weak gravity is and how far away our instruments are from detecting individual particles gravitationally.
You mean the region where people looking for grants to search for them said they could exist so that their experiments would be sensitive to them.Alain_BXL said:I was thinking mainly about WIMPs, which have historically been the main focus of DM research. Based on what I've read, it seems that experimental results have gradually excluded most of the region in which WIMPs were originally anticipated to exist.
You do not need SUSY to have particle dark matter. You also do not need a typical WIMP dark matter candidate.Alain_BXL said:SuSy particles haven't yet been detected at the LHC despite high expectations (granted, more work remains to be done).
Alain_BXL said:PBHs can only make-up a small part of the universe's total mass/energy budget given our current understanding of nucleosynthesis.
And there seems to be a growing acceptance that MACHOs don't solve the missing mass problem.
I realize that there's lots of room between the weak force and gravity. But I still find the DM hypothesis intellectually inelegant, which was my original point. Modified gravity seems a more parsimonious and elegant approach.
Orodruin said:That conclusion does not come from nucleosynthesis. Depending on the PBH mass, there are different experimental searches ruling out PBH from being all of dark matter. For the very lightest masses, the bounds come from black hole evaporation, but in some mass ranges you can go as high as tens of per cent.
Orodruin said:First of all, nature does not care about what you find elegant.
Not really. You get much stronger bounds from the fact that you still need them to be around today without observing any black holes in the final stages of evaporation in order for them to be dark matter.Alain_BXL said:Sure but doesn't our knowledge of nucleosynthesis place limits on the number of "small" PBHs, precisely because their evaporation would have affected the baryon/photon ratio and thereby also affected nucleosynthesis.
To a particle physicist, it seems much more elegant if you can solve several problems in one go, which is typically what we try to do with particle dark matter models. We know that the standard model is not the whole story, we just don't know what should replace it.Alain_BXL said:To my layman's eye, it seems more parsimonious/elegant to tweak gravity than to invent ever more complicated hypotheses to explain DM.
It postulates that dark matter is not its own anti-particle, yes. You try to make a theory where you get an asymmetry (much like in the baryon sector) in the early Universe. The typical problem that you try to solve at the same time is the baryon asymmetry.Alain_BXL said:I'll try to fix that although it seems anything but a parsimonious theory: do I understand correctly that it postulates both DM and anti-DM?
Hi Alain:Alain_BXL said:I thought the 1st modern usage of the term was by Zwicky in the 1930s.
Dale said:It doesn’t predict gravitational time dilation or the correct light deflection or the precession of Mercury or the Shapiro effect or frame dragging.
Dale said:Perhaps. I admittedly have not followed any recent developments of MOND, having examined them and lost interest in them quite some time ago. It could be that something new has overcome previous problems.
What I have seen from MOND theories at best is capable of explaining galaxies, but fails at both cosmological scales and local scales. I have yet to see a MOND theory which is not contradicted by already existing evidence at cosmological scales and at local scales.
If you know of a MOND theory which is consistent with all currently available evidence at all scales then I would be glad for a reference.
Thanks, that is interesting and quite helpful!ohwilleke said:There are modified gravity theories such as Moffat's MOG theory that works at galaxy cluster and cosmological scales. Deur's gravitational approach to understanding dark matter
Neither was GR, but it did it anyway. That is a large part of what makes GR so compelling and MOND not, in my mind. They both do what they were designed to do, but GR also explains many things that it was not designed to explain, completely new gravitational phenomena that were not even conceived before the theory. MOND does not.ohwilleke said:MOND isn't meant to do any of those things.
I disagree completely with the final statement. Until the generalization is actually developed MOND indeed fails locally. As you noted yourself, such a generalization is necessary but not trivial and attempts so far have failed.ohwilleke said:perfectly described reality would have to be a general relativistic generalization of MOND ... So, there is no failure of MOND at local scales
John Ferree said:at the quantum level, it is both a wave and a particle.
John Ferree said:Is it possible that Dark Matter is gravity, itself?
Got it. Thanks.weirdoguy said:No it is not - wave-particle duality is an outdated concept and is not part of modern quantum physics.
Gravity is a curvature of spacetime, so based on the meaning of 'curvature of manifold' and 'dark matter' the answer is 'no'.
