Is dx Negative in Non-Standard Analysis?
  • Level: High School
  • Thread starter Thread starter etotheipi
    Dx Negative
49 replies · 11K views · last reply
By definition:
$$\lim_{\Delta x \to 0} \frac{f\left(x + \Delta x\right) - f(x)}{\left(x + \Delta x\right) - x} = \lim_{\Delta x \to 0} \frac{f\left(x + \Delta x\right) - f(x)}{\Delta x } = \frac{d\left(f(x)\right)}{dx}$$
So if ##dx = \lim_{\Delta x \to 0} \left(x + \Delta x\right) - x##, I don't see why it couldn't be arbitrarily chosen to be negative. It wouldn't change anything to the final result in a derivative or an integral as ##d\left(f(x)\right)## will change sign accordingly.
##\lim_{\Delta x \to 0} \left(x + \Delta x\right) - x = 0##
WWGD said:
Edit:Well, not the dx itself but the values dx assumes.
##dx## is not a number and doesn't assume any values. ##x## is assumed here to be a real variable, so it and ##f(x)## assume real values. But ##dx## is a notational device to indicate, along with the ##\int## symbol, integration with respect to the variable ##x##.
You can say, for example, let ##x = 1##, then ##f(1)## is well-defined, but ##d1## or ##dx \big | _{x = 1}## has no meaning.
You say ##dx## is a notational device, does this mean we just give it meaning when dealing with differentials? For instance, for probability density functions I like to think of it this way:
(The increment in cumulative probability) = (the probability per unit increment of ##x##) multiplied by (the increment of ##x##), namely ##dF = f(x) dx##, and then we just insert an integral sign with bounds to turn this from an equation of differentials to full statement, i.e. ##\int_{P_{1}}^{P_{2}} dF = \int_{a}^{b} f(x) dx##.
So whilst I used to think of ##\int ... dx## as a single unit with some stuff in the middle, I now sort of think of it as two separate units, ##[\int][f(x)dx]##, inline with the concept of a sum.
This question comes up quite often I think. On the one hand, the theory of calculus, both differential and integral, is independent of the notation used. There is no theorem that depends on an interpretation of ##dx##. That said, the relationship between integration and differentiation and hence the relationship between ##dx## in an integral and the differential ##dx## allows some neat shorthand notation - especially for applied maths and physics. For example, integration by substitution is actually:
$$\int_a^b f(u(x))u'(x)dx = \int_{u(a)}^{u(b)} f(u)du$$
And, if you sit down and prove this, then it does not rely on cancelling ##dx## as in:
$$\int_a^b f(u)\frac{du}{dx}dx = \int_{u(a)}^{u(b)} f(u)du$$
Simply cancelling the ##dx## here is not a proof! In real analysis (pure mathematics) it must be proved otherwise.
@etotheipi
If in doubt, always look for the tangents. They are hidden somewhere when it comes to differentiation.
It is the quotient ##\dfrac{\Delta f(x)}{\Delta x}##, i.e. the slope of the hypotenuse of the triangle which must be considered, not just one kathode, whether as ##\Delta x## or as ##dx##. The limiting process of simultaneously both kathodes, the lengths of the difference of function values and the lengths of the ##x## intervals. The quotient does the trick!
If it stands alone, it abbreviates something else and things are more complex, namely a differential form. This is the function that attaches another function to each point: ##x \longmapsto L_x## (see post #6). My picture used ##y=\frac{1}{5}x^2## and ##x_0=3##. So ##dx## attaches the function ##\tilde{x} \longmapsto \frac{2}{5} \tilde{x}##, which has at ##x_0=3## the value ##\frac{6}{5}##. Here we changed the origin of the curve space ##(0,0)## into the origin at the tangent space (the green line) ##(3,\frac{9}{5})## which becomes our new origin if we talk about the tangent space as a vector space. Hence the tangent at ##x_0=3## is ##f'(\tilde{x})=(\frac{2}{5}\cdot 3) \tilde{x}## which is a linear function in the coordinate system of the tangent. In old coordinates it is ##f'(x)=\frac{6}{5}x - \frac{9}{5}##. One of the things which adds more confusion and requires to distinguish the curve from the tangents. Every single tangent is a line, i.e. a one dimensional vector space: different points ##x_0##, different tangent spaces. At school it is all in one coordinate system, whereas physicists have to distinguish the ##(x,y)## space above from all the possible green lines, e.g. the one I drew in the picture with ##(\tilde{x},f'(\tilde{x}))## coordinates. That's why a tangent should always be considered as the pair ##(x_0, L_{x_0})##, the point of evaluation and the direction (slope) which it points to. This distinction is basically the secret behind all other perspectives under which a differentiation can be seen.
  • Love
That's helpful, thank you. My "rule" is that we're "allowed" to effectively cancel infinitesimals but not operators, as in $$\frac{dy}{dx} dx = dy$$ whilst I'd need to change the following $$\frac{d}{dx} (\frac{dy}{dx}) dx = \frac{d(\frac{dy}{dx})}{dx} dx = d(\frac{dy}{dx})$$ The difference isn't too noticeable in the below example, but it seems to be important in things like operator equations.
But I think like you say it's more a case of taking advantage of the notation.
  • Skeptical
It's not precisely a "below example"; it's above the text that refers to it; but it's nevertheless a good example; and, at least in my view, a little bit of notational abuse can sometimes be rather good. :wink:
I meant when you integrate it does take numerical values. The simplest case, integrate 1dx from 0 to 1. The answer will be 1(1-0)=1. Dx is a measure of the width of an interval. When we do a Riemann integral, we're doing an infinite sum f(x_j)dx_j. dx_j := x_{j+1}-x_j. So dx_j is the measure of the length of an interval. Sure, with infinite Riemann sums we do not consider each, but you may use a partition into finitely-many rectangles and assign a length to each. You may then say dx_i:=x_{j+1}-x_j=0.5, etc. So it is not just a place-holder, though maybe you said it in a different sense. So you can say dx_i or dx at the ith interval assumes the value x_{j+1}-x_j = Real number.
There are no sub-intervals in an integral and it is not an infinite sum. It's the limit of a sequence of finite sums. An infinite sum is something of the form:
$$\sum_{n= 1}^{\infty} a_n$$
If the integral was an infinite sum, it would defined as such, with the approriate width ##dx_j## specified! There are no ##dx_j## in an integral. There is only the symbol ##dx##, which is neither a number nor an interval.
You do have an infinite sum where the terms are of the form f(x_j)dx_j and, you specify additional conditions by quantifying over all sums where dx_j goes to 0.
Well, yes, the limit of a sum, not necessarily an infinite sum. The with dx_j is a variable, and you do not specify it for infinitely-many values, but it does assume values. You may partition [0,1] into [0,1/2], [1/2,1]. Then dx_(interval [0,1/2])=1/2-0 and dx_(interval[1/2,1])=1-1/2=1/2. So you do assign actual numerical values. Of course, in the limit you do a quantification over all intervals , over all sums as width goes to zero but these are actual widths. But maybe it is a semantic thing and we are saying the same thing in different ways.
Perhaps, but just as example. In the integral
$$\int_0^1 x^2 dx$$
What is the value of the width(s) ##dx_j## that you would use?
The Riemann integral when it converges to R is the limit of a net of intervals/partitions ordered by inclusion into the Reals. You want, if Partition 1 subset Partition 2, both in an eps- neighborhood of R. You assign a Riemann sum to each partition so that , by net convergence, every subpartition is eventually in any eps-neighborhood of R. I don't know if I explained it well, but I think the net convergence issue is a bit unwieldy.
Guess my post was confusing. My point is that the convergence of the Riemann integral is not your standard convergence but instead convergence as a net.
How about looking at it as a state space?
I've actually got some notes on doing the following integral from first principles, by calculating the limits of the upper and lower sums for a set of regular partitions:
$$\int_a^b x^2 dx$$
Note that the definite integral (unlike ##dx##) is a real number!
We take ##P_n## as the partition of ##[a, b]## into ##n## equal sub-intervals of width ##\frac{b -a}{n}##. Note that each partition has sub-intervals, but the integral itself does not.
The minimum value of ##x^2## on each interval is at the lower end and the maximum at the higher end. This gives us the upper and lower sums as:
$$L_n = \sum_{k = 0}^{n-1} (a + \frac{k}{b-a})^2(\frac{b-a}{n}) \\
= (b-a)[a^2 + (b-a)^2\frac{(n-1)(2n-1)}{6n^2} + \frac{a(b-a)(n-1)}{n}] \\
U_n = \sum_{k = 1}^{n} (a + \frac{k}{b-a})^2(\frac{b-a}{n}) \\
= (b-a)[a^2 + (b-a)^2\frac{(n+1)(2n+1)}{6n^2} + \frac{a(b-a)(n+1)}{n}]$$
Each of the ##L_n## must be an under-estimate of the integral and each of the ##U_n## must be an over-estimate. If they both converge to the same number, then that number is the integral.
Now, we have:
$$\lim_{n \rightarrow \infty} L_n = \frac 1 3 (b^3 - a^3) \\
\lim_{n \rightarrow \infty} U_n = \frac 1 3 (b^3 - a^3)$$
The definite integral, therefore, is well-defined and we have:
$$\int_a^b x^2 dx = \frac 1 3 (b^3 - a^3)$$
Yes! This reminded me of something that happened with me. I was trying to determine the work of gravity (or ##F_{spring}##, I forgot) after having fixed a positive direction.
When I considered the position to be increasing, I found the correct answer, but then, when considering the case where the position was decreasing, I got a wrong one. I then caught that in ##\vec F\cdot d\vec s=|F|\,|ds|\cos\theta## the ##ds## must be negative, so ##|ds|=-ds##.
PeroK said:
Perhaps you didn't phrase this precisely, but a real number is either zero or it's not. It can't "go to zero". In any case, ##dx## in the integral is not a real number.
Hm, hasn't Abraham Robinson formalised infinitesimals?
In post #46 I showed how the integral of ##x^2## could be done from first principles using "standard" real analysis. I invite you to do the same using non-standard analysis, where ##dx## is an infinitesimal.
The following proposition is a cornerstone of real analysis. Let ##x \in \mathbb R## with ##x \ne 0##.
1) Either ##x > 0## or ##x < 0##, but not both.
2) If ##x > 0##, then ##\exists \ y \in \mathbb R, \ s.t. \ 0 < y < x##.
If this proposition fails for ##dx##, then ##dx \notin \mathbb R##.
Right, REAL analysis.
No experience with non-standard analysis 🤷‍♂️.
