Is electric field decomposable when detected by CCD?
1 reply · 1K views · last reply
genxium
I'm learning light interference and confused by the concepts. Like the figure I attached below, while computing the "interference" of the intersection point on the CCD, I used to do this ([itex]E[/itex] represents the electric field):
[itex]E_{CCD}=E_1 \cdot e^{i (\omega t + \frac{2 \pi}{\lambda} l)} + E_2 \cdot e^{i (\omega t + \frac{2 \pi}{\lambda} (l+d \cdot sin \alpha))}[/itex]
I know this is wrong because electric field is directional and I should decompose it so that only components in the same direction add up -- yet I'm not sure how to do it. Does a CCD detector respect the direction of fields?
Described above.
Described above.
  • Diagram of two point sources H1 and H2 with electric field arrows E1 and E2, a ray from H2 to a CCD screen at angle alpha, distance l horizontal and d vertical separation.
I don't know why you can't use traditional ray optics with the CCD at the location of the real image. You need to focus on a CCD just like on a screen or film. But perhaps I'm way off base here.
