Is gravity's speed really the speed of light?
  • Context: Undergrad
  • Thread starter Thread starter Veridian
    Gravity
The discussion revolves around the nature of gravity, specifically whether it has a speed and how this relates to gravitational waves and the curvature of spacetime. Participants explore conceptual frameworks and analogies to understand these phenomena, touching on theoretical implications and the propagation of gravitational effects.
  • Some participants express confusion about how gravity can have a speed, questioning the concept of propagation in relation to gravity and gravitational waves.
  • Others clarify that in a static configuration of gravity sources, gravity does not propagate, as it is a constant curvature of spacetime.
  • One participant argues that gravity does not have a speed per se, likening it to magnetic attraction, while suggesting that gravitational effects are due to spacetime curvature.
  • Another participant agrees that the "speed of gravity" refers to the speed at which changes in the metric propagate, rather than gravity itself having a speed.
  • Some participants use analogies, such as a bowling ball on a trampoline, to illustrate gravitational attraction, though this analogy is challenged by others for its limitations in representing spacetime dynamics.
  • One participant introduces the concept of propagation using the analogy of ripples in water, suggesting that all waves, including gravitational waves, propagate outward from a source.
  • There are corrections regarding the nature of gravity as an effect caused by spacetime curvature, rather than something that affects spacetime.
  • Some participants critique the trampoline analogy, arguing it fails to accurately represent the complexities of gravitational interactions and general relativity.
  • The existence of gravitational waves is mentioned as well-established, with references to Nobel Prize-winning research suggesting they propagate at the speed of light.
Participants express differing views on the nature of gravity and its speed, with some agreeing on the conceptual framework of gravity as an effect of spacetime curvature, while others contest the adequacy of analogies used to explain these concepts. The discussion remains unresolved regarding the validity of certain analogies and the implications of gravity's speed.
Limitations include the reliance on analogies that may not fully capture the complexities of general relativity and the propagation of gravitational waves. There is also a lack of consensus on the interpretation of gravity's speed and its implications.
Veridian
I am slowly learning more and more about physics, but one issue I've come across is understanding how gravity can have a speed. I was under the impression that gravity couldn't have a speed. I know gravity can be visualized as just curvature in spacetime, but how is it that something that is seemingly everywhere can even have a speed? What is propagation and how does it relate to gravity and gravitational waves?
Thank you for your time and knowledge.
Right. With a static configuration of gravity sources nothing propagates. Gravity, described as spacetime geometry, is just there, everywhere.
Changes in spacetime geometry propagate as gravitational waves, with a finite speed. Compare this to static E-fields vs. EM-waves which propagate with a finite speed.
As you mentioned, gravity effects spacetime - just as a bowling ball does on a trampoline.
What you wanted to know is about gravity having speed - what i want to correct is that gravity doesn't have a 'speed' as such. Gravity is an attraction - like a magnet. Magnets do not have a speed, but they do have a variable representing its magnetic strength.
So, to explain how gravity works, imagine the bowling ball on a trampoline. If you 'place' a tennis ball, it rolls downhill towards the bowling ball. Just like will planets, the smaller mass is attracted to the larger.
I hope this helps. This is how I envision gravitational attraction
A minor correction. Gravity, the attraction of one object to another, is an effect. It is caused by the curvature of spacetime by mass and energy. Gravity doesn't affect spacetime, it is caused by spacetime.
Agreed. The "speed of gravity" is actually the speed at which changes in the metric propagate.
And the larger mass is attracted to the smaller one as well. :biggrin:
Imagine throwing a pebble into a pond. The ripples in the water move outwards from the point of impact with a certain speed. We call this movement, propagation. IE, the wave propagates outward from the source. This is the case for all waves, including gravitational and EM waves.
Ah, thank you for that! My mistake aha. You are right, gravity is the effect caused by the curvature of space time just like how the speed at which the tennis ball moves towards the bowling ball if due to the curvature of the trampoline!
The trampoline(aka rubber sheet) analogy is flawed in many ways. For one, you're explaining gravity with gravity(What makes the bowling ball push on the trampoline? What makes the tennins ball move down the indentation?). Another problem is that you're supposed to represent the curvature of spacetime, and there is no time dimension in the picture.
We've had many threads about it, here's the most recent one:
https://www.physicsforums.com/showthread.php?t=760793
Its true that it isn't a sound analogy, but It does show the same outcome, does it not?
No, it doesn't. You can't get anything similar to the precession of Mercury's orbit out of it, for example.
It's a sound visualisation of gravitational potential well, and how bodies move according to Newtonian gravity. But once you invoke spacetime, you're talking about General Relativity, and the analogy is no longer valid.
I see... well, I'll keep that in mind. Thanks
  • · Replies 22 ·
  • · Replies 34 ·
  • · Replies 21 ·
  • · Replies 45 ·
  • · Replies 29 ·
  • · Replies 22 ·
