Is it by definition that i^2=-1
  • Context: Undergrad
  • Thread starter Thread starter pivoxa15
    Definition
38 replies · 7K views
pivoxa15
Is it by definition that i^2=-1 or is it worked out from more fundalmental laws?
i^2 could also have been 1. It depends how one evaluates the square.
1. Multiply the two numbers inside the two squareroots first than square root the product (i.e. sroot(a)sroot(a)=sroot(a*a)=a)
or
2. Cancel the squareroot and leave the number (that was before inside the square root) alone (i.e. sroot(a)sroot(a)=(sroot(a))^2=a)
From the definition of i^2, the second option was chosen.
For real numbers it did not matter which option one chose but complex numbers posed a problem. I think Euler first used option 1 for this operation. I got this information from 'Mathematics: The Loss of Certainty' by Morris Klein.
If it is an axiom than why option 2 instead of 1?
pivoxa15 said:
1. Multiply the two numbers inside first than square root the product
This is a fallacy. You in general can NOT just move things in and out of square-roots, because they are multiple-valued (not functions!). You only get a legitimate function if you specify which root you're taking. With real numbers, this is defined to be the positive square root. In this instance the square root gets squared, so there's no ambiguity:
[tex]i^2=\left(\sqrt{-1}\right)^2=-1\neq\sqrt{(-1)^2}[/tex]
The problem with this is that it is a multiple value function because of the way i is defined.
My understanding is that i is defined to be the solution to the equation x^2 +1 = 0, or x^2 = -1, then taking the positive square root of both sides so that i = sqrt (-1). Since at the time there was no such thing as the square root of a negative number, i was chosen to represent that number. They could have chosen to take the negative square root instead, which means the definition would have been i = -sqrt(-1). Those are the only possible definitions.
Hmm, pivoxa15, we define i2 = -1. We don't "evaluate" it. :wink:
Or more precise, we define the imaginary unit i to be the pair of numbers (0, 1), since there are up to 2 square roots of -1.
Defining i by asserting that "i2= -1" doesn't work because there are two complex numbers that have that property (i and -i). Defining i to be [itex]\sqrt{-1}[/itex], or, equivalently, as the positive number such that i2= -1 both are invalid because the complex numbers cannot be made into an ordered field so we cannot distinguish between the two numbers in that way.
We can define the complex numbers to be pairs of real numbers (a,b) with addition and multiplication defined by (a,b)+ (c,d)= (a+c,b+d) and
(a,b)*(c,d)= (ac- bd,ad+bc). That can be shown to be a field. Also the sub-field of pairs of the form (a,0) can be shown to be isomorphic to the real numbers with natural isomorphism a->(a, 0). Finally, (0,1)*(0,1)= (-1, 0) so we call that "i", as VietDao29 said, and then write i2= -1. It is also true that (0,-1)*(0,-1)= (-1,0): (0,-1) is, of course, the additive inverse of (0, 1) and so we call it "-i".
daveb said:
... then taking the positive square root of both sides so that i = sqrt (-1). Since at the time there was no such thing as the square root of a negative number, i was chosen to represent that number. They could have chosen to take the negative square root instead...
There is no such thing as an ordering on the complexes that makes i positive at all in any meaning full sense that behaves well with respect to arithmetic.
proof:
suppose i>0, since mutlipying an inequality by a positive number preserves the inequality i can multiply that by i on both sides to obtain -1>0. I leave it to you to see that assigning i<0 also makes no sense.
When I said positive square root I didn't mean to imply an ordering on the complex field. I just couldn't think of any other way to put it. My point was that the historical basis for i was when mathematicians tried to find solutions to the equation x^2+1=0. They couldn't find any solutions in the reals, so had to invent the imaginary numbers. At least that's what my calc teachers had told me way back when.
So this is the proper way to define complex numbers.
What about the two options I listed in post 1?
Is it just a coincidence or a consequence that i^2=-1 follows option 2?
'The' proper way? No, not really though it is probably the best. The 'proper' definition is the algebraic closure of the reals, and the description given is one way to produce a model of this, as is the quotient ring R[x]/(x^2+1).
Often in maths there is some abstract 'proper' definition, and that doesn't help you ever work out what the thing looks like. For example, a 'proper' (by which I technically mean categorical) definition of something might be:
given two sets A, B we'll define the product to be a set C with maps to A and B such that for any for other set D with maps to A and B the maps factor uniquely through C.
But of course if you ever need to think about what the product of A and B is it is the set of ordered pairs (a,b), isn't it?
And you first post with the '2 options' doesn't actually make anysense. You don't, for instance, say what it is that you're squarerooting in your options.
In any case, the proper way to squareroot something is to pick an argument in some specified region (-pi/2 to pi/2 or 0 to pi depending on your preference). It is called taking the principal value.
In light with the previous post I should say that option 2 is less wrong than option 1.
http://en.wikipedia.org/wiki/Order_of_operations
The order of operations is expressed in the following chart.
exponents and roots
multiplication and division
addition and subtraction
You have to cancel or combine the square-roots first which means you are left with the original term (inside the sqaure root priori to the squaring) alone. The result is not obtained from multipling the term inside the square roots first than squaring the whole thing. Because roots first than multiplication and not vice versa
I did say that I was operating on numbers (real or complex). They are the only numbers I had in mind. I was describing things are an intuitive or elementary level which I hope is consistent with the proper definitions.
matt grime said:
Can I suggest you reread your first post.
Take this for instance:
"1. Multiply the two numbers inside first than square root the product
or"
Which two numbers inside what?
Sorry I have made my original post clearer, I hope.
I realized that the two options yield the same result when considering real numbers only. Because sroot(a)*sroot(b)=sroot(ab) whether a=b or not.
But if operating on complex numbers than option 1 is completely different to option 2. i.e. sroot(a)*sroot(b), when the sroots are evaluated individually and than multiplied, does not equal sroot(ab) where a,b are complex numbers. Hence the oder of operation rules are important when operating roots of complex numbers.
Using Euler's identity is a nice way of confirming that i^2=-1
I wonder how he came up with this way of representing complex numers. Why is the base e instead of something else. e doesn't come into play until you differentiate the complex number. So that might be the reason for e.
Why is it more "natural" to define complex numbers as ordered pairs? The definition of multiplication, for example, (a,b)*(c,d)= (ac- bd,ad+bc), is not intuitive at all from this POV. If you defined it as something of the form a+bi then it is obvious.
Once you have the series solution for [tex]e^{t}[/tex] you could well ask yourself 'I wonder what happens when t = ix', probably what Euler did.
[tex]e^{t} = \sum_{n=0}^{\infty}\frac{t^{n}}{n!}[/tex]
[tex]e^{ix} = \sum_{n=0}^{\infty}\frac{(ix)^{n}}{n!} = \sum_{n=0}^{\infty}\frac{i^{n}x^{n}}{n!} = \sum_{n=0}^{\infty}\frac{i^{2n}x^{2n}}{(2n)!}+\sum_{n=0}^{\infty}\frac{i^{2n+1}x^{2n+1}}{(2n+1)!}[/tex]
[tex]= \sum_{n=0}^{\infty}\frac{(-1)^{n}x^{2n}}{(2n)!}+i\sum_{n=0}^{\infty}\frac{i^{2n}x^{2n+1}}{(2n+1)!} = \sum_{n=0}^{\infty}\frac{(-1)^{n}x^{2n}}{(2n)!}+i\sum_{n=0}^{\infty}\frac{(-1)^{n}x^{2n+1}}{(2n+1)!} = \cos x + i \sin x[/tex]
Just a matter of playing around with the summations, though you get the series for [tex]e^{x}[/tex] from it's property of differentiation as you mention.
Another way (which I didn't know, but mathworld just informed me) is to consider
[tex]z = \cos x + i\sin x[/tex]
[tex]dz =( -\sin x + i\cos x )dx = i(\cos x + i\sin x )dx = izdx[/tex]
Rearrange and integrate to get [tex]\ln z = ix[/tex] so [tex]z = e^{ix} = \cos x + i\sin x[/tex]
But how do you define i unambguously? That was the point.
Because throoughout high school you are told "square roots of negative numbers do not exist". This is of course nonsense, I can define a square root of anything arithmetic as a symbol whose square is what we started with, but we don't teach maths like that to kids.
Thus, people come to imaginary numbers (even the name is silly) with a long history of thinking what you're about to do is absolutely wrong because their teacher told them. For some reason many kids think that their high school teacher is more of an authority on mathematics than anyone else.
With the ordered pair view point you are able to construct a field for them that is algebraically closed without any more ontological commitment: they know what real numbers are, they damn well ought to know about ordered pairs (or vectors, really), and this is a nice construction that completely sidesteps the need to introduce a new symbol that they are preconditioned to believe does not exist, nay, cannot exist.
You should not use this explanation to actually work with, but it is a very useful gadget to show that you're not doing something illegitimate after all.
You are just showing that R^2 can be endowed with the structure of a division algebra (that happens to be commutative); R^4 also has a division algebra structure, and this leads to many interesting questions about which other R^n are division algebras (possibly non-associative).
dextercioby said:
Circular logic. We use [itex]i^2 =-1[/itex] to prove Euler's formula.
Daniel.
How would you derive Euler's formula from i^2=-1? By randomly guessing relationships between different areas in math? Finally come upon the a relationship between complex numbers and trig?
I imagine it would have been easier and more natural to derive Euler's formula from the two ways mentioned by AlphaNumeric and most likely how Euler orginally came up with his formula. i^2=-1 just became a consequence of this elegant relationship.
Two things go against your reasoning: History and the playfulness of mathematicians. Bombelli developed the imaginary numbers in the 1570s. Leibniz revived the idea 100 years later. Taylor developed the mathematics behind power series in 1715. The power series representations of exp(x), sin(x), and cos(x) are obviously closely allied. All it took was a little imagination to see the relationship. Have you never just taken an equation apart and played with it?
AlphaNumeric derived Euler's formula given i^2 = -1.
I did not look at the proof given by AlphaNumeric properly. i^2=-1 was an assumption built into the derivation. i^2=-1 is not a consequence but an axiom of this derivation.
Euler probably had access to the Talyor series when he developed his famous formula because in 1715 he was only 8 and surely he would have developed that formula at a later stage of his life.
So it is only by accepting i^2=-1 that Euler's formula can exist and the formula is certainly an elegant result. It could have been that he allowed i^2=-1 just so that this relationship could stand. Its a bit like 'the elegance of this formula proves that i^2=-1' since there was no logical basis at the time for i^2=-1 or 1. Remember that he once thought that i^2=1. Interestingly he did not consider representing the complex numbers on a plane which would have made his formula more plausible.
robphy said:
This is a gem: "Visual Complex Analysis" by Needham. The website http://www.usfca.edu/vca/ has some information and excerpts.
I was looking into that text, but now seeing the contents, I'm doubting whether or not this book is really as good as the reviews say. I'm going to give it a shot regardless since there is no harm in doing so.
It just seems like there is an unecessary amount of material.
It depends on what you'll use it for. As a textbook for a non-math major, it may not be appropriate. For me, it provides some interesting ways and insights into what is going on in the complex plane... (e.g., numerous ways to motivate the de Moivre theorem).
For my money that is morally different from asserting 'he thought that i^2=1' as that comes with the implication that he thought that what we call i squares to 1, whereas what he was playing with wasn't what we now call i in some sense (ie he demonstrably had it behaving differently, and something is characterized by its behaviour), but this might just be my formalist sensibilities being offended.
There's nothing wrong with Euler making a mistake. He wasn't perfect. If anything, he probably thought he put a "-" in front, but because he had bad eye sight, he couldn't confirm it. :approve:
You can't be afraid to be wrong. You just have to accept that you were wrong and correct your logic.
Sometimes being wrong is better than being right. If you got bad logic running around and everyone (teachers) say you're right, that will hurt you a lot in the long run.
