Is it Monday or Tuesday at exactly 12:00 midnight?
  • Thread starter Thread starter mitsuk0
    Time
The discussion centers around the question of what day it is at exactly 12:00 midnight, particularly whether it is considered Monday or Tuesday. Participants explore the implications of time notation, the definitions of AM and PM, and the conceptual boundaries of time measurement.
  • Some participants argue that 12:00 AM is Tuesday, as it follows 11:59 PM on Monday.
  • Others propose that there is a discontinuity at midnight, suggesting that it is a unique moment that could be seen as both Monday and Tuesday.
  • A participant mentions that 12:00 PM is noon, which complicates the assignment of AM or PM to midnight.
  • Some argue that the definition of a day could be seen as less than 24 hours due to the nature of time representation with finite and infinite decimals.
  • Another viewpoint suggests that both noon and midnight are neither AM nor PM, as they represent transitional moments.
  • There is a suggestion that using a 24-hour clock could clarify the ambiguity surrounding midnight.
Participants express differing views on whether 12:00 midnight should be classified as Monday or Tuesday, with no consensus reached. The discussion remains unresolved, with multiple competing perspectives on the nature of time and its representation.
Participants reference the confusion surrounding AM and PM designations, particularly at transitional times like midnight and noon. The discussion highlights the limitations of conventional timekeeping and the potential for ambiguity in definitions.
mitsuk0
K.. sorry i didn't search and don't know if this was already a thread. At the time of 12:00 midnight.. EXACTLY.. what day is it.. Say it was 11:59 on monday then 12:00.. 12:00 exactly, not 1 value over it.. say time like froze on 12:00 precisely.. would it be monday or tuesday?
There is just a 2nd order discontinuity in the day name.
Well since 11:59:59.999 (for any finite number of 9s) is Monday PM clearly 12:00:00.000 AM is Tuesday.
no... that means a day is not 24 hours but 23:59.99999999999999999999
That is why I said for a FINITE number of nines. An infinite number as you imply is 12:00 since .999... =1
LOL
The message you have entered is too short. Please lengthen your to at least 10 characters.
yes
a day is 23:59.99999999999999999999999999999999999999999999999999999999999 hours long
but what is smallest physical meaning of time:it is 10 to the power (-23) seconds, beyond that time has no physical meaning[in fact this time is equal to the time taken by a particle traveling at the speed of c to crosss a nucleus).
So it is just same as 24 hours.
Keep Smiling
Malay
More seriously: Monday 12:00 p.m. is the same instant as Tuesday 00:00 a.m. And yes, at this precise instant it is Monday AND Tuesday. Happily this ambiguous situation lasts only 0 seconds.
unfortunately for this argurment 12PM is noon. Just a fraction of a second after 11:59:59 AM
Well the problem is the same with 12:00 (noon). Noon is not ante-meridiem nor post meridiem is just meridiem. Then 12h (noon) is neither am nor pm.
I can rewrite the same post in the European way to write the time:
More seriously: Monday 24:00 is the same instant as Tuesday 00:00. And yes, at this precise instant it is Monday AND Tuesday. Happily this ambiguous situation lasts only 0 seconds.
Is it better this way PF mentor?
I don't see that way, Seems straight forward, clearly 12:00:01am is Tuesday. So why is it so difficult to assign 12:00 am to Tuesday?
lpfr said:
I think that you should read the entry:
http://en.wikipedia.org/wiki/12_hour_clock
And perhaps you should read this;
This article or section does not adequately cite its references or sources.
Please help improve this article by adding citations to reliable sources. (help, get involved!)
Any material not supported by sources may be challenged and removed at any time. This article has been tagged since March 2007.
I see. I think inutile to continue this argument.
This question is analogous to asking whether zero is positive or negative. Zero is the boundary between positive and negative but zero itself is neither positive or negative. Similarly, midnight and noon are neither AM nor PM. They are midnight and noon.
From http://www.physics.nist.gov/News/Releases/questions.html"
Are noon and midnight 12 a.m. or 12 p.m.?
This is perhaps the trickiest time question of them all. The best answer is that the terms 12 a.m. and 12 p.m. cause confusion and should not be used.
To illustrate this, consider that "a.m." and "p.m." are abbreviations for "ante meridiem" and "post meridiem." They mean "before noon" and "after noon," respectively. Of course, noon is neither before nor after noon; it is simply noon.
When accuracy matters, the 24-hour clock should be used, otherwise "noon" and "midnight" are a better fit than 12 AM/PM which is undefined. But since "Tuesday at midnight" can be either morning or evening then Tuesday at 00:00 or Tuesday at 24:00 makes the difference clear. Once again, the 24-hour clock saves the day.
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 18 ·
