Is it possible to decompose a vector into non-perpendicular components?
2 replies · 2K views
physics user1
[/B]
[/B]
When I have to describe a motion I'm supposed to decompose a vector in two directions, for example in an inclined plane is decompose the weight in these directions: the normal to the plane and the parallel to the plane, and that seems logic, but could I decompose the weight in other directions? The same thing for the velocity in a parabolic motion, I decompose the velocity in the vertical and the horizontal directions because it is easier but could I describe the motion using other directions?for example the horizontal and another one inclined with the horizontal by an angle different of 90 ?
I think I could because it's a matter of choice, the motions doesn't change, changes just the way you look at it
[/B]
You are free to make these choices. Often you can turn a difficult problem into an easy one by a clever choice of coordinate directions.
Cozma Alex said:
2. Homework Equations [/B]
[/B]
When I have to describe a motion I'm supposed to decompose a vector in two directions, for example in an inclined plane is decompose the weight in these directions: the normal to the plane and the parallel to the plane, and that seems logic, but could I decompose the weight in other directions? The same thing for the velocity in a parabolic motion, I decompose the velocity in the vertical and the horizontal directions because it is easier but could I describe the motion using other directions?for example the horizontal and another one inclined with the horizontal by an angle different of 90° ?
In regard to your last question:
"... for example the horizontal and another one inclined with the horizontal by an angle different of 90° ?"​
You can decompose a vector into two components which are not mutually perpendicular. However, that tends to cause more problems than it solves..
