Is it possible to find the limit of (1+1/x)^x as x approaches -infinity?
The discussion revolves around finding the limit of the expression (1+1/x)^x as x approaches negative infinity. Participants explore various methods and reasoning to arrive at a conclusion, while debating the validity of their approaches without relying on L'Hôpital's rule.
  • Some participants suggest that the limit approaches e as x approaches negative infinity, drawing parallels to the limit as x approaches positive infinity.
  • Others propose that the limit could be 1/e, but this is contested by those asserting it is e.
  • Several participants attempt to manipulate the expression by substituting variables, such as letting y = -x, to analyze the limit as y approaches positive infinity.
  • One participant mentions the potential of using the natural logarithm and Taylor expansion to analyze the limit, suggesting it may yield insights into the behavior of the function.
  • Another participant raises concerns about treating infinity as a real number, emphasizing the need for caution in such manipulations.
  • There are discussions about approximations and whether certain transformations lead to valid conclusions about the limit.
Participants express differing views on the limit, with no consensus reached. Some argue for e, while others suggest 1/e, and various methods are proposed to support these claims.
Participants note that some methods involve approximations and transformations that may not be standard, leading to uncertainty about the validity of their conclusions.
This discussion may be of interest to those studying limits in calculus, particularly in the context of exponential functions and their behavior at infinity.
manjuvenamma
Is it possible to find the limit of (1+1/x)^x as x approaches minus infinity using only the fact that it is e if x approaches infinity?
1/e??
Niladri Dan said:
1/e??
No, the answer is e. We have to find a reason without using LHospital's rule.
What happens, if you write ##y=-x## and consider ##y \to +\infty##?
I thought about it but got stuck up. Then it becomes (1-1/y)-y as y approaches infinity which is not a standard formula.
Maybe, but ##a^{-y}=(\frac{1}{a})^y## is.
but 1+1/y is different from 1-1/y. That is where I am stuck.
For ##y \to \infty##? Isn't it only the difference between left and right?
I am not sure if this helps but what if you multiply by the conjugate and then try to think why ##\lim_{y \to \infty} \left(1 - \frac{1}{y^2}\right)^y## should be 1.
A great idea but I am not able to think of a proof that it is 1. If this is proved, then I agree that the original question is proved. But how to prove that? It raises other similar interesting questions like what about (1-1/y^3)^y, (1-1/y^4)^(y^2) etc.
I think this problem can be solved in this way. Here is what I think:-
let x = -1/y
then, Lt (1+1/x)x where x→ -∞
=> Lt (1 - y)-1/y where y→ 0
Now let -y = 1/p
then, Lt (1 - y)-1/y where y→ 0
=> Lt (1+1/p)p where p→∞
And this is equal to e.
You have
A=\lim _{x\rightarrow\infty} (1+1/x)^x=e
B=\lim _{x\rightarrow\infty} \left(\frac{1}{1-1/x}\right)^x
AB=\lim _{x\rightarrow\infty}\left(\frac{1+1/x}{1-1/x}\right)^x=\lim _{x\rightarrow\infty}(1+2/x)^x=\lim _{x\rightarrow\infty}\left((1+2/x)^{x/2}\right)^2=e^2
I am not able to figure out how 1+2/x came. Is it an approx?
Yes, it is an approximation. 1/(1-a) ≈ 1+a and (1+a)2≈1+2a for |a|<<1 . As x-->∞, 1/x -->0 and you can substitute 1/(1-1/x) with (1+1/x). The second approximation is not needed as you have (1+1/x)x already.
1/(1-a) is the sum of the geometric series 1+a+a2+... . If a <<1, the higher order terms can be neglected.
@ ehild, Great explanation. Thanks to all the respondents who took time to clarify things to me. I would like to know how to write math equations here, is there a link? Is there a way I can accept the answer and close as the raiser of this question?
To write nice equations use LaTeX : https://www.physicsforums.com/help/latexhelp/
There are useful symbols also under the ∑ key, and you can make subscript and superscript with the x2 and x2 keys.
I think, closing a thread is possible in the Homework Forum only.
This question has been intriguing me, so I've gave it a shot:
$$\left(1+\frac{1}{x}\right)^x = \left(\frac{1+x}{x}\right)^x$$
With ##\infty##:
$$\left(\frac{1+\infty}{\infty}\right)^{\infty}$$
With ##-\infty##:
$$\left(\frac{1-\infty}{-\infty}\right)^{-\infty} = \left(\frac{\infty - 1}{\infty}\right)^{-\infty} = \left(\frac{\infty}{\infty - 1}\right)^{\infty}$$
And one can see that:
$$\frac{\infty}{\infty - 1} = \frac{1+\infty}{\infty}$$
Where the numerator is just 1 + the denominator (like ##\frac{101}{100}## or ##\frac{1000}{999}##). Thus it should give the same answer when at infinity.
With ##\infty##:
With ##-\infty##:
This shouldn't get on my desk for correction.
@fresh_42 I agree. They could do a better job of solving this. Suggestion in computing ## y=## limit ## (1+\frac{1}{x})^x ## in a couple of the above posts is to take the natural log of this expression, (so that you have ## ln(y)=x \, ln(1+\frac{1}{x}) ##), use a Taylor expansion of ## ln(1+\frac{1}{x}) ##, (in the form of ## ln(1+u ) ## where ## u ## is small), and then take ## e^{ln(y )}=y ##.
Here's a direct method
##\lim_{x\to-\infty}\left(1+\frac{1}{x}\right)^x = \lim_{y\to\infty}\left(1-\frac{1}{y}\right)^{-y} = \lim_{y\to\infty}\frac{1}{\left(1-\frac{1}{y}\right)^y}= \lim_{y\to\infty}\left(\frac{y}{y-1}\right)^{y}.##
Now let ##w = y-1##. Clearly ##y\to\infty## is equivalent to ##w\to\infty##. So
##\lim_{w\to\infty}\left(\frac{w+1}{w}\right)^{w+1}= \lim_{w\to\infty}\left[ \left(1+\frac{1}{w}\right)^w\left(1+\frac{1}{w}\right) \right] = e\times 1 = e## as required.
Think about a "subsequence" of the function you've mentioned when x=n an integer. You know that the main sequence and subsequence have the same limit.
With ##\infty##:
With ##-\infty##:
It's not legitimate to treat ##\infty## as if it were an ordinary real number.
? Not sure what you mean here.
##\displaystyle \lim_{x\to-\infty}\left(1+\frac{1}{x}\right)^x = \lim_{y\to\infty}\left(1-\frac{1}{y}\right)^{-y} = \left(\lim_{y\to\infty}\left(1-\frac{1}{y}\right)^y\right)^{-1} = (e^{-1})^{-1} = e##
Is this correct ?
This:
Even in cases where such considerations might lead to correct results, I find it a bad habit to use them - far too dangerous w.r.t. possible errors. And by no means this should be taught, IMO. Maybe it can be used to get roughly a picture of the situation, but even this can already be misleading.
FWIW, I did not treat ##\infty## as a real number, otherwise the following wouldn't be true:
But I admit that it would've looked a lot more professional by using ##x## and ##\displaystyle \lim_{x \rightarrow \infty}##. That is why I liked post #20 which essentially demonstrate the same thing I did. So this should be better:
$$\lim_{x \rightarrow \infty}\frac{x}{x - 1} = \lim_{x \rightarrow \infty}\frac{1+x}{x}$$
Try to graph this:
[1-(1/(-x))]^(-x)
Understanding that the shaded region in the below graph, for the equation "y= 1/x", is equal to 1 square unit.
