Is it wrong? (A theorem of limits)
  • Context: Undergrad
  • Thread starter Thread starter Adit
    Limits Theorem
The discussion revolves around the limit of the function \(\frac{\sin x}{x}\) as \(x\) approaches zero, exploring various methods of evaluation including L'Hôpital's rule, geometric interpretations, and series definitions. Participants examine the implications of using L'Hôpital's rule in this context and its potential circularity, as well as alternative definitions of sine and cosine.
  • Some participants question the area of sector MOA, suggesting it should be \(2\pi^2/x\) and seek clarification on this point.
  • One participant proposes using L'Hôpital's rule to evaluate \(\lim_{x\rightarrow 0}\frac{\sin x}{x}\), stating that it leads to a limit of 1.
  • Another participant argues that using L'Hôpital's rule to establish \(\lim_{x\rightarrow 0}\frac{\sin x}{x}=1\) is circular, as this limit is often used to derive the derivative of \(\sin x\).
  • Some participants provide geometric interpretations of the area of a circular sector and relate it to the limit being discussed.
  • Alternative definitions of sine and cosine are introduced, including power series and solutions to differential equations, which do not rely on geometric arguments.
  • There is a suggestion that using L'Hôpital's rule in this context may not be pedagogically sound, especially for students who are new to the concept.
Participants express differing views on the appropriateness of using L'Hôpital's rule for evaluating the limit, with some asserting it is circular while others defend its use. There is no consensus on the best approach to take in this situation.
Participants highlight the potential circular reasoning involved in using L'Hôpital's rule to evaluate the limit, as well as the reliance on definitions and assumptions regarding sine and cosine. The discussion remains open to various interpretations and methods.
Adit
In attachments, there is a pic of a page, I think there area of sector MOA should be 2π^2/x. Please tell me how this makes sense?
I would solve this with L’Hospital's rule
\begin{align}
\frac{f(x)}{g(x)}:= \frac{sin(x)}{x}\qquad \text{ since}\quad g'(x)\neq 0,
\end{align}
it follows with L’Hospital's rule
\begin{align}
\lim_{x\rightarrow 0}\frac{f(x)}{g(x)}=\lim_{x\rightarrow 0}\frac{f'(x)}{g'(x)} =\lim_{x\rightarrow 0} \frac{cos(x)}{1}=1,
\end{align}
Adit said:
View attachment 71628 In attachments, there is a pic of a page, I think there area of sector MOA should be 2π^2/x. Please tell me how this makes sense?
The area of a circular sector of radius ##r## spanned by an angle ##\theta## is ##\frac{1}{2}r^2\theta##. Alternatively (and used by this text), the area is ##\frac{1}{2}rL##, where ##L=r\theta## is the length of the arc of the circle of radius ##r## spanned by the angle ##\theta##.
\begin{align}
\end{align}
\begin{align}
\end{align}
One usually uses the fact that ##\lim\limits_{x\rightarrow 0}\frac{\sin x}{x}=1## to establish ##\frac{d}{dx}\sin x=\cos x##. Using ##\frac{d}{dx}\sin x=\cos x## in the process of using l'Hopital's rule to show that ##\lim\limits_{x\rightarrow 0}\frac{\sin x}{x}=1## is a circular argument.
For a full circle, the centre angle is 2π radians (one full lap), and the area is πR2. For a sector of a circle, it is clear that the area A is proportional to the the centre angle θ.
Since θ=2π corresponds to A=πR2, it follows that in general: θ/2π = A/πR2, which gives A=θR2/2. In particular: if R=1, A=θ/2.
Also, by the definition of a radian, if x is the length of the circle sector, θ=x (if R=1).
Using L'Hôpital's rule to calculate the limit ##\lim_{x\to 0}\frac{\sin x}x## is no good idea, because it would probably be circular: this limit is in most cases used in the calculation of the derivative of ##\sin x##.
Usually, but not necessarily. There are other ways of defining "sine" and "cosine" that do not require a geometric way of getting the derivative of sin(x) and cos(x).
For example, we can define sin(x) to be the power series
\sum_{n=0}^\infty \frac{x^{2n+1}}{(2n+1)!}
and define cos(x) to be the power series
\sum_{n=0}^\infty \frac{x^{2n}}{(2n)!}
Those series have infinite radius of convergent so converge uniformly on any finite interval and, in particular are differentiable "term by term" at any x. Differentiating the series for sin(x) term by term gives
\sum_{n= 0}^\infty\frac{(2n+1)x^{2n}}{(2n+1)!}= \sum_{n= 0}^\infty\frac{x^{2n}}{(2n)!}= cos(x).
Another way to define sine and cosine are as solutions to an 'initial value problem':
Define cos(x) to be the function, y(x), satisfying the differential equation y''= -y with the initial conditions y(0)= 1, y'(0)= 0,
Define sin(x) to be the function, y(x), satisfying the differential equation y''= -y with the initial conditions y(0)= 0, y'(0)= 1.
By the fundamental "existence and uniqueness" theorem for differential equations, there exist unique functions satisfying those. In particular, if y is the derivative of sine, if y(x)= (sin(x))' then y'(x)= (sin(x))''= -(sin(x)) so that y''(x)= -(sin(x))'= -y. That is, y(x)= (sin(x))' satisfies the same differential equation. Further, y(0)= (sin(x))' at 0 which is 1. y'(0)= -(sin(0))= 0. That is, the derivative of sin(x) is cos(x).
If we use the power series definition, then $$\frac{\sin x}{x}=\sum_{n=0}^\infty \frac{x^{2n}}{(2n+1)!}$$ for all ##x\neq 0##, and the limit can be solved by direct substitution.
If we use the DE definition, then, for ##y(x)=\sin x## we get $$\lim_{x\rightarrow 0}\frac{\sin x}{x}=\lim_{x\rightarrow 0}\frac{y(x)-y(0)}{x-0}=y'(0)=1$$ for free using the definition of the derivative.
So the use of l'Hopital's Rule to solve the limits given either of those definitions, while not circular, is a bit ham-handed. Though I guess I'll need to rephrase my comment ...
It's bad pedagogy to advise students to use l'Hopital's rule to evaluate ##\lim\limits_{x\rightarrow 0}\frac{\sin x}{x}##. It's especially bad when you have been reminded that that vast majority of students asking about that limit are (a) learning about that limit so that they can turn around and use it to prove things about the derivatives of trig functions and (b) likely weeks away from even hearing about l'Hopital's rule.
  • · Replies 20 ·
