Is mathematics only used with quantitative data?
Mathematics is not solely reliant on quantitative data, as many branches, such as geometry and topology, operate without direct numerical involvement yet have significant applications in fields like physics. Higher-level mathematics often emphasizes abstract concepts over numerical computations, focusing on functions and symbols instead. While certain applied math fields do involve numbers during computations, theoretical aspects predominantly deal with abstractions like sets and mappings. The misconception that math is primarily about numbers overlooks the diverse applications of non-numerical branches. Overall, mathematics encompasses a wide range of applications beyond just quantitative data.
Tosh5457
Can mathematics only be applied when there are numbers involved? I know there are mathematics branches like mathematical logic that doesn't deal with numbers, but do those areas have applications outside of mathematics?
Mathematics news on Phys.org
It depends on what you mean. There are many fields which do not work with numbers directly, like geometry and topology. And these fields have important application in physics.
The colored patterns using shapes is a basic math topic, but it applies to physics to read color coded resistances.
It seems to me that in "higher" math, the higher the math is, the less you deal with numbers. Even in areas such as differential equations, where the objects you're dealing with are defined in a way that makes reference to numbers, you may almost never deal with them (not counting an occasional e or 2pi). Instead you talk about functions and work with symbols.
I think it's a fundamental mistake to think that math is primarily about numbers.
^ It depends on the field and what you mean by "dealing with numbers." If you mean computations, then sure. If you mean literally "seeing" numbers, you'll be getting quite used to them in particular applied math fields (numerical analysis, analysis, PDEs, ODEs, etc.). You usually don't deal with numbers until you actually get down to the computations. In the theory of these fields, it's still mostly abstractions (elements, sets, mappings, etc.).
But in other fields as mentioned, you almost never use numbers to deal with anything. Rather you're almost never working in the set of reals again. You simply work with mappings and properties of new definitions, seeing what comes from it (geometry/topology, algebras, logic, etc.).
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
